BugSir009 Posted November 11 Report Share Posted November 11 Maxthon PC 7.3.1.1105 alpha * Optimized bookmark multi-column menu spacing. - Fixed an issue with incorrect browser version time display. - Fixed an issue with incognito mode display in themes. - Fixed unclear tab divider line display in third-party themes. - Fixed an issue where some video sites prompted flash playback errors. - Fixed known crashes. https://github.com/maxthon/Maxthon/releases/download/7.3.1.1105/maxthon_7.3.1.1105_x64_alpha.exehttps://github.com/maxthon/Maxthon/releases/download/7.3.1.1105/maxthon_7.3.1.1105_x86_alpha.exehttps://github.com/maxthon/Maxthon/releases/download/7.3.1.1105/maxthon_portable_7.3.1.1105_x64_alpha.ziphttps://github.com/maxthon/Maxthon/releases/download/7.3.1.1105/maxthon_portable_7.3.1.1105_x86_alpha.zip 3 2 Quote Link to comment Share on other sites More sharing options...
saman_rm Posted November 12 Report Share Posted November 12 In this new version, the search engine returns to default after setting it to Google. Quote Link to comment Share on other sites More sharing options...
BugSir009 Posted November 12 Author Report Share Posted November 12 2 hours ago, saman_rm said: In this new version, the search engine returns to default after setting it to Google. Hi saman_rm, could you disable all extensions and try again? Quote Link to comment Share on other sites More sharing options...
projektilski Posted November 12 Report Share Posted November 12 My saved credit cards are missing from PassKeeper. I have entries, such as name and expiration dates, but no credit card numbers. Gone. Quote Link to comment Share on other sites More sharing options...
TarMaster Posted November 12 Report Share Posted November 12 (edited) 10 hours ago, BugSir009 said: Maxthon PC 7.3.1.1105 alpha * Optimized bookmark multi-column menu spacing. - Fixed an issue with incorrect browser version time display. - Fixed an issue with incognito mode display in themes. - Fixed unclear tab divider line display in third-party themes. - Fixed an issue where some video sites prompted flash playback errors. - Fixed known crashes. https://github.com/maxthon/Maxthon/releases/download/7.3.1.1105/maxthon_7.3.1.1105_x64_alpha.exehttps://github.com/maxthon/Maxthon/releases/download/7.3.1.1105/maxthon_7.3.1.1105_x86_alpha.exehttps://github.com/maxthon/Maxthon/releases/download/7.3.1.1105/maxthon_portable_7.3.1.1105_x64_alpha.ziphttps://github.com/maxthon/Maxthon/releases/download/7.3.1.1105/maxthon_portable_7.3.1.1105_x86_alpha.zip Maxthon PC 7.3.1.1105 alpha * Optimized bookmark multi-column menu spacing. Unfortunately, the distance between the menu lines has increased. The row spacing was much better in the MX 7.2.2.6000 version. Bookmarks in MX 7.2.2.6000 version: Bookmarks in MX 7.3.1.1105 alpha version: Edited November 12 by TarMaster 1 Quote Link to comment Share on other sites More sharing options...
migel Posted November 12 Report Share Posted November 12 Hi, every time open, close Maxthon, the gmail asks for username and password. 1 Quote Link to comment Share on other sites More sharing options...
saman_rm Posted November 12 Report Share Posted November 12 7 hours ago, BugSir009 said: Hi saman_rm, could you disable all extensions and try again? i have no any extentions Quote Link to comment Share on other sites More sharing options...
elnoos Posted November 12 Report Share Posted November 12 (edited) hello thanks for your work please, in this version, the little floating video window do not expand to full screen. please, fix it Edited November 12 by elnoos 2 Quote Link to comment Share on other sites More sharing options...
Mhzayer Posted November 12 Report Share Posted November 12 I still face the issue that maxthon doesn't take links from other apps when it's open after I close it, it opens the links I guess this happens after updating maxthon bandicam 2024-11-12 20-05-53-074.mp4 Quote Link to comment Share on other sites More sharing options...
Rackerkind Posted November 12 Report Share Posted November 12 Hello, the DRM problem still persists. I can watch the video in Google Chrome, Microsoft Edge, Brave, Firefox and Opera browsers. Quote Link to comment Share on other sites More sharing options...
Refix2 Posted November 12 Report Share Posted November 12 13 hours ago, TarMaster said: Maxthon PC 7.3.1.1105 alpha * Optimized bookmark multi-column menu spacing. Unfortunately, the distance between the menu lines has increased. The row spacing was much better in the MX 7.2.2.6000 version. That's right, the lines are spaced wider and the menu has become longer 4 hours ago, Mhzayer said: I still face the issue that maxthon doesn't take links from other apps when it's open after I close it, it opens the links I guess this happens after updating maxthon I confirm, links do not open from other applications when Maxthon is open. The same link opens when Maxthon is closed and it is launched 2 Quote Link to comment Share on other sites More sharing options...
BugSir009 Posted November 13 Author Report Share Posted November 13 18 hours ago, projektilski said: My saved credit cards are missing from PassKeeper. I have entries, such as name and expiration dates, but no credit card numbers. Gone. Hi projektilski, do you have a backup copy of user data? Quote Link to comment Share on other sites More sharing options...
BugSir009 Posted November 13 Author Report Share Posted November 13 17 hours ago, TarMaster said: Maxthon PC 7.3.1.1105 alpha * Optimized bookmark multi-column menu spacing. Unfortunately, the distance between the menu lines has increased. The row spacing was much better in the MX 7.2.2.6000 version. Bookmarks in MX 7.2.2.6000 version: Bookmarks in MX 7.3.1.1105 alpha version: Hi TarMaster, I have checked with the development team and they mentioned there were some issue with the UI for this new chromium. This will be fixed subsequently. 1 Quote Link to comment Share on other sites More sharing options...
BugSir009 Posted November 13 Author Report Share Posted November 13 17 hours ago, migel said: Hi, every time open, close Maxthon, the gmail asks for username and password. Hi migel, have feedback to the development team for them to check on it. 16 hours ago, saman_rm said: i have no any extentions Hi saman_rm, I have informed the development team to check on it. In the meantime, could you try clearing your browser cache and try again? 9 hours ago, elnoos said: hello thanks for your work please, in this version, the little floating video window do not expand to full screen. please, fix it Hi elnoos, have feedback to the team for further check. 9 hours ago, Mhzayer said: I still face the issue that maxthon doesn't take links from other apps when it's open after I close it, it opens the links I guess this happens after updating maxthon bandicam 2024-11-12 20-05-53-074.mp4 Hi Mhzayer, thanks for the video. Have forwarded it to the team and they will look into it. 7 hours ago, Rackerkind said: Hello, the DRM problem still persists. I can watch the video in Google Chrome, Microsoft Edge, Brave, Firefox and Opera browsers. Hi Rackerkind, the team will look into this issue once the new chromium is more stabilized. 2 Quote Link to comment Share on other sites More sharing options...
TarMaster Posted November 13 Report Share Posted November 13 5 hours ago, BugSir009 said: Hi TarMaster, I have checked with the development team and they mentioned there were some issue with the UI for this new chromium. This will be fixed subsequently. Super! Thank you! Quote Link to comment Share on other sites More sharing options...
projektilski Posted November 13 Report Share Posted November 13 6 hours ago, BugSir009 said: Hi projektilski, do you have a backup copy of user data? I'm sorry, but this is a bug in a new version. I have 7.2.2.x installed, and it shows the credit card number when auto filling and even on the Passkeeper page. 7.3.1.1102 7.2.2.4600 Quote Link to comment Share on other sites More sharing options...
migel Posted November 13 Report Share Posted November 13 7 hours ago, BugSir009 said: On 11/12/2024 at 11:22 AM, migel said: Hi, every time open, close Maxthon, the gmail asks for username and password. Hi migel, have feedback to the development team for them to check on it. Thank you! Quote Link to comment Share on other sites More sharing options...
Refix2 Posted November 15 Report Share Posted November 15 When trying to import files (bookmarks), Maxthon closes. This error occurs in the installation version and in PT System Win'11Pro x64 23H2, Maxthon x1105 Quote Link to comment Share on other sites More sharing options...
migel Posted November 15 Report Share Posted November 15 On 11/13/2024 at 11:35 AM, migel said: On 11/12/2024 at 11:22 AM, migel said: Hi, every time open, close Maxthon, the gmail asks for username and password. Hi migel, have feedback to the development team for them to check on it. It's not just gmail that loses the passwords, but something is happening with all the Google accounts and the passwords are lost for no reason after a few hours of Maxthon being open and not when I close Maxthon as I thought. 1 Quote Link to comment Share on other sites More sharing options...
suphamster Posted November 15 Report Share Posted November 15 How to clear cookies for current visited/opened site? In previous core there where "cookies and site data button" to the left of site adress and now there aren't anything similar. Quote Link to comment Share on other sites More sharing options...
alexzhus Posted November 15 Report Share Posted November 15 18 minutes ago, suphamster said: How to clear cookies for current visited/opened site? In previous core there where "cookies and site data button" to the left of site adress and now there aren't anything similar. On the left, as before, click on the site settings, the page will open, you will see it there. 1 Quote Link to comment Share on other sites More sharing options...
Refix2 Posted November 15 Report Share Posted November 15 21 minutes ago, suphamster said: How to clear cookies for current visited/opened site? In previous core there where "cookies and site data button" to the left of site adress and now there aren't anything similar. Settings => privacy and security => "site setting" section => All pages and here you choose the one you are looking for 3 Quote Link to comment Share on other sites More sharing options...
AaronX Posted November 16 Report Share Posted November 16 I installed a few days ago - possibly Monday itself, thinking about it - and all has been okay, but today (Saturday) I turn on my computer and everything's gone. Logged out of Maxthon, session and all open tabs wiped, most extensions (but not all) uninstalled. Various settings back to default, and all cookies wiped. Frustrating! I did install Opera on my computer yesterday evening to test a user's error report on a website I run, but that shouldn't have been able to affect Maxthon, surely? Quote Link to comment Share on other sites More sharing options...
saman_rm Posted November 17 Report Share Posted November 17 passkeepr (address) not work It is not possible to add an address 1 Quote Link to comment Share on other sites More sharing options...
Mhzayer Posted November 17 Report Share Posted November 17 1 hour ago, saman_rm said: passkeepr (address) not work It is not possible to add an address I confirm on installed version on win11 Quote Link to comment Share on other sites More sharing options...
SEYMOUR Posted November 17 Report Share Posted November 17 The data and avatar are missing. Quote Link to comment Share on other sites More sharing options...
alexzhus Posted November 17 Report Share Posted November 17 (edited) 1 hour ago, SEYMOUR said: The data and avatar are missing. Everything works. Avatar and data are present. Edited November 17 by alexzhus Quote Link to comment Share on other sites More sharing options...
Drowasec Posted November 17 Report Share Posted November 17 (edited) Good afternoon! In Maxthon PC 7.3.1.1105 alpha, tabs automatically go into sleep mode, even when the option is disabled, in the version of Maxthon PC 7.2.2.6000 it worked fine, tabs do not enter sleep mode. Also, when you try to synchronize, it fails, when you turn on the VPN, there is no failure Новый точечный рисунок (2).bmp Авторизация.bmp Edited November 17 by Drowasec Quote Link to comment Share on other sites More sharing options...
BugSir009 Posted November 18 Author Report Share Posted November 18 On 11/15/2024 at 9:31 PM, Refix2 said: When trying to import files (bookmarks), Maxthon closes. This error occurs in the installation version and in PT System Win'11Pro x64 23H2, Maxthon x1105 Hi Refix2, could you send me the crash report? On 11/17/2024 at 12:01 AM, AaronX said: I installed a few days ago - possibly Monday itself, thinking about it - and all has been okay, but today (Saturday) I turn on my computer and everything's gone. Logged out of Maxthon, session and all open tabs wiped, most extensions (but not all) uninstalled. Various settings back to default, and all cookies wiped. Frustrating! I did install Opera on my computer yesterday evening to test a user's error report on a website I run, but that shouldn't have been able to affect Maxthon, surely? Hi AaronX, may I know which version were you using previously? And for this current version, were you using install or portable version? On 11/17/2024 at 10:39 AM, saman_rm said: passkeepr (address) not work It is not possible to add an address Hi saman_rm, bug reported. Quote Link to comment Share on other sites More sharing options...
BugSir009 Posted November 18 Author Report Share Posted November 18 12 hours ago, Drowasec said: Good afternoon! In Maxthon PC 7.3.1.1105 alpha, tabs automatically go into sleep mode, even when the option is disabled, in the version of Maxthon PC 7.2.2.6000 it worked fine, tabs do not enter sleep mode. Also, when you try to synchronize, it fails, when you turn on the VPN, there is no failure Новый точечный рисунок (2).bmp 3.35 MB · 4 downloads Авторизация.bmp 991.54 kB · 3 downloads Hi Drowasec, could you delete this file: 'User Data\Local State' and try again? 1 Quote Link to comment Share on other sites More sharing options...
Join the conversation
