Maxthon PC 7.2.2.5000
BugSir009
13 hours ago, Mhzayer said:
Yes
If not solved it will ask again even in safe mode
BTW BugSir
I found an issue with Google Max search
If you search for anything that has the symbol &
search will ignore anything after it
I was trying to search for "j&t express customer service"
the search result will only serach for j
and ignore anything after it
even if you put it between double quotes "j&t express customer service"
it will search for "j
and ignore the rest
Hi Mhzayer, thanks for informing. I will inform the development team about this issue.
  • Like 1
On 9/30/2024 at 8:39 PM, 1bit said:
Иookmarks are not synced. This already happened in the previous update.
Version 7.2.2.5000
I still have some serious sync problems since they changed the "database format" of bookmarks + notes. If I'm importing the old data stored in previous format, I'll retrieve my old notes, but as soon I'll import bookmarks into Maxnotes (using "superbookmarks") with the "Import bookmarks to Maxnote folder" function, my maxnote are completely f*cked. The imported bookmarks are not complete and then if I try to do any modification, the database is goind wild, refreshing in an endless loop...
They have applied the Tchernobyl theorem: updating a functional system to destroy it. Well done guys 👌!!!
It turned out to be a very strange version. Every day, when I first launch the browser, some disabled extensions are randomly enabled. Also, the MxVideoCapture extension still starts automatically, which I don't need. I'm starting to suspect that it's a spy.
Edited by Chemodan
18 minutes ago, Zanzibar said:
Can't use "Enhancer for YouTube" Add-In https://chromewebstore.google.com/detail/enhancer-for-youtube/ponfpcnoihfmfllpaingbgckeeldkhle
Error: Товар не совместим с установленной версией Chrome (~ This item is not compatible with your Chrome version)
Mensioned this a few versions ago
the problem is in the core
They told me to wait for the new chromium core to be updated which won't be in the near future
Let's be honest here
Keeping compatibility to Windows 7 for Chinese users is their main concern and the new chromium doesn't support it
So don't expect to see it coming
Unless the devs which are only a few split their efforts into two separate Maxthons version 8 where the chromium keeps updating and version 7 to have millions of Chinese users happy
  • Like 1
  • Sad 1
Many extensions like this one can’t be used in Maxthon because of its outdated core and reliance on Manifest V2. I worry that if the development team doesn’t make changes, Maxthon might soon become obsolete due to compatibility issues.
  • Like 5
  • Sad 1
Quote
Is there a way to download and install old (compatible) version of "Enhancer for YouTube" Add-In?
I generally have one set of notes on my work computer and another set on my home computer. Although both show synchronization.
I conclude that using Maxton bookmarks is becoming very unsafe in terms of data loss.
This morning, everything disappeared from the notes.
Has Maxton turned off this service altogether?
On 10/4/2024 at 4:30 PM, Mhzayer said:
After installing new version exit Maxthon
replace your userdata with whatever backup you want then restart Maxthon
I did everything as you wrote.
I copied Maxton from my work computer. This is the copy where the necessary notes are.
I installed a clean copy of Maxton. Renamed it to OLD. I copied the version from my work computer in its place.
After synchronization, I return the clean copy, synchronize and get the old incomplete notes in it.
On 10/2/2024 at 3:26 PM, grisp1 said:
Hello @BugSir009
I'm having a bookmark sync issue again with the last few builds—one computer is completely out of sync. Hitting the 'Sync' button starts the process, and no errors are shown, but the changes aren't synced on other PC/Mobile clients.
Please advise.
Add:
Log doesn't show any error but looks weird:
[12832:12836:1002/144058.220:INFO:messages_control.cc(2137)] [js_sync] send sync once
[12832:12836:1002/144058.220:INFO:mxsyncmgrimpl.cc(809)] starting sync by method `DoSync()`
[12832:12836:1002/144058.220:INFO:mxsyncmgrimpl.cc(463)] sync type: 1 Not enabled here.
[12832:12836:1002/144058.220:INFO:mxsyncmgrimpl.cc(463)] sync type: 2 Not enabled here.
[12832:12836:1002/144058.220:INFO:mxsyncmgrimpl.cc(463)] sync type: 3 Not enabled here.
[12832:12836:1002/144058.220:INFO:mxsyncmgrimpl.cc(463)] sync type: 4 Not enabled here.
[12832:12836:1002/144058.220:INFO:mxsyncmgrimpl.cc(463)] sync type: 5 Not enabled here.
[12832:12836:1002/144058.220:INFO:mxsyncmgrimpl.cc(463)] sync type: 6 Not enabled here.
[12832:12836:1002/144058.220:INFO:mxsyncmgrimpl.cc(463)] sync type: 7 Not enabled here.
[12832:12836:1002/144058.220:INFO:mxsyncmgrimpl.cc(463)] sync type: 8 Not enabled here.
[12832:12836:1002/144058.220:INFO:mxsyncmgrimpl.cc(463)] sync type: 9 Not enabled here.
[12832:12836:1002/144058.721:INFO:messages_control.cc(2246)] [js_sync] send event to check dirty and sync
[12832:12836:1002/144058.723:INFO:radis_bookmark_control.cc(333)] PushServiceBookmarks  length:345253
[12832:20184:1002/144058.724:INFO:mxqasyncImpl.cc(158)] OnGetNewUploadData http://localhost:47602/quickaccess/sync?new=1
[12832:20444:1002/144058.728:INFO:mx_internal_rest_client.cc(336)] http://localhost:47602/quickaccess/sync?new=1 and get data length:385766
[12832:12836:1002/144058.732:INFO:mx_request_control.cc(101)] MxNetRequestCount:0
[12832:12836:1002/144059.566:INFO:web_dialog_manager.cc(1232)] [js_sync] handle newData event with name: bookmarks, ver: 6349
[12832:12836:1002/144059.569:INFO:radis_bookmark_control.cc(333)] PushServiceBookmarks  length:345253
I had the same issue
  • Like 1
The steps should be in this order
1. take a copy of the userdata folder you want to keep
2. Make a clean install of latest Maxthon version and run it with your account then exit Maxthon
3. Replace your new userdata with the backued up in step 1 then restart Maxthon
I did everything exactly like that.
But if I perform a new installation again, the notes in it are old again and many of them are not included.
Although they are in the copy from the work computer.
staying on chrome 109 is just a bad decision and potentially unsafe.
Users who are still on win7/8 should be using Supermium, latest version is based on chrome kernel 126 and still runs fine on win 7/8. If they can do it, I don't get why maxthon devs are still stuck on kernel 109...  Supermium is open source, just take a peek at how things should be done.
Get your shit together maxthon devs ! Microsoft is ending support for win 7,8,10 by october 2025. Is that when you will finally decide to do the most important thing you should be doing instead of adding useless vpn, crypto and AI shit ? any unique feature of Maxthon can now be replicated with addons in a superior way, and we (I'm still counting myself as a maxthon user even though technically, I've moved to vivaldi) are just losing support for vital addons like enhancer for Youtube and websites and services (Slack ???) weeks after weeks because devs are not updating the damn kernel.
the new maxthon tagline should be "the last browser running on chrome 109"... This is just pathetic imo.
  • Like 9
  • Sad 1
Hello,
I've been a user since 2009 and the truth is that they've been very late in adjusting the versions aimed at the users.
Perhaps it's because I'm no longer part of the users that the developers want to add.
Old engine, they took away all the accumulated points, several crashes, and now the extensions are not compatible.
They are making (or not) a real effort so that, at least on my part, I definitely move to a more optimal browser for the times we live in.
Greetings.
  • Like 3
On 10/13/2024 at 7:42 PM, setth said:
Hello,
Greetings.
Unfortunately
We oldtime users love Maxthon but because "Abundance overcome courage"
Don't think that for just some thousand English and Win10 and 11 users that they are going to make Maxthon work the way you do
while million Chinese win7 users are going to be ignored
Finger crossed
A genius Maxthon lover with great IT score will come up with a sollution or
develop a new Maxthon like browser that have all its Maxthon 5 and newer great features
and be specifically designed with the latest chromium core in advance
Then we will all be happy and almost all issues are going to be gone
Good to be very optimistic about it or see it as a dream that oneday will be a reality
  • Like 3
I don't know about actual user numbers, but occasionally I lurk on the Chinese language forum and there are increasing numbers of vocal users over there who are also complaining about the old Chromium kernel version and extensions that no longer work. It is not just English (or other language) speakers here who are unhappy, if that is any consolation.
Which translates as There have been frequent updates recently, and they are all official versions, but why don’t they update the kernel? Comments like these are frequent with each update.
Edited by new user
  • Like 3
  • Thanks 1
Thanks this might be true for Chinese users outside of China
After all
alas this war will never end
Version: 7.2.2.5200(64 bit)1014 14:24
I did everything as you wrote, the notes were partially restored, half is lost.
You have really upset me with the latest versions. I no longer trust your browser as a note keeper.
First the bookmarks broke, now the notes. Everything is very sad.
  • Like 1
Yes. Maxnote was once awesome! But now I am paying about $25 a year for a competitive cloud based note app, and for the reliability and amount of storage I get it is worth it. Maxnote was once a very good reason to use Maxthon, but now as you say it is only sad.
  • Like 2
As I see it:
Either there are not enough rights during installation and Maxton should be installed by a user with administrator rights, or Maxton has problems working on Windows 10 LTSC. In any case, Maxton's functionality does not work fully.
  • 1 month later...
Thank! Now in Maxthon  PC 7.3.1.1701 beta "Enhancer for YouTube" Add-In works fine
Join the conversation
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
