BugSir009 Posted September 29 Report Share Posted September 29 Maxthon PC 7.2.2.5000 + Added a free AI answering feature in MaxAsk: Just add a "?" to your search term to instantly view AI answers. You can set MaxAsk as your default search engine in "Settings - Search Engine" for a more convenient search experience. + Added new synchronization module for syncing extensions. + Added Passkeeper feature for exporting plaintext passwords in CSV format. + Added tab setting option: When the current page is a 'New Tab', all links will open in the current page without creating a new tab; + Added close setting option: Automatically exit the browser when the last tab is closed. * Optimized login and synchronization speed. - Fixed an issue with excessive disk usage on startup. - Fixed an issue with failing to retrieve weather data. - Fixed an issue where extension sync installation displayed the extension introduction page. - Fixed known crashes. https://github.com/maxthon/Maxthon/releases/download/7.2.2.5000/maxthon_7.2.2.5000_x64.exehttps://github.com/maxthon/Maxthon/releases/download/7.2.2.5000/maxthon_7.2.2.5000_x86.exehttps://github.com/maxthon/Maxthon/releases/download/7.2.2.5000/maxthon_portable_7.2.2.5000_x64.ziphttps://github.com/maxthon/Maxthon/releases/download/7.2.2.5000/maxthon_portable_7.2.2.5000_x86.zip 1 2 Quote Link to comment Share on other sites More sharing options...
Zura Chelidze Posted September 30 Report Share Posted September 30 The core is the same😒 Chrome/109.0.0.0 Safari/537.36 1 1 Quote Link to comment Share on other sites More sharing options...
suphamster Posted September 30 Report Share Posted September 30 42 minutes ago, Zura Chelidze said: The core is the same😒 Chrome/109.0.0.0 Safari/537.36 It could be told even without downloading by MX version number. I guess that one with updated core would be v7.5 or even 8.0. Quote Link to comment Share on other sites More sharing options...
ZorMi Posted September 30 Report Share Posted September 30 I expect the new core will not be compatible with Win7, so probably Maxthon v8. Quote Link to comment Share on other sites More sharing options...
Chemodan Posted September 30 Report Share Posted September 30 (edited) Hello! As in previous versions: When I first launched the new version of the browser, I had to log in again. As if the user profile was deleted. All disabled extensions are enabled again and their home pages are opened. Just like before, some settings are not restored after synchronization: 1. Quick launch panel settings (tile size, selected background and showing/disabling the search bar, weather...). 2. The update check setting is enabled again, although it should always be disabled. 3. The path to the downloads folder is reset to the default path. 4. Additional functions section settings. ... The browser still cannot correctly render some sites on the quick access panel and page thumbnails look torn. And this is not a problem with the old kernel version, since Vivaldi and Opera work fine on the same non-updated kernel. In this regard, I repeat my request: 1. If the browser cannot correctly show pages miniatures, open these settings for the user so that the user himself can insert the desired image. 2. Optionally display the name of the page on miniature (as the names of folders are now shown). MX Portable, Windows 7 Edited September 30 by Chemodan Quote Link to comment Share on other sites More sharing options...
Mhzayer Posted September 30 Report Share Posted September 30 15 hours ago, BugSir009 said: + Added a free AI answering feature in MaxAsk: Just add a "?" to your search term to instantly view AI answers. You can set MaxAsk as your default search engine in "Settings - Search Engine" for a more convenient search experience. Quote Link to comment Share on other sites More sharing options...
MichaelC362 Posted September 30 Report Share Posted September 30 (edited) 15 hours ago, BugSir009 said: + Added close setting option: Automatically exit the browser when the last tab is closed. Hello! I'm so glad this is optional as it's the feature I dislike the most in other browsers! I notice the weather location was lost after installing this release... was that intentional? Any chance the 'multi-search' feature will ever be added back? I always found that useful, especially when searching for anything technical... Google would generally find zero (to be expected as no advertising revenue), but was handy to have DuckDuckGo, Ask & Yandex results available Edited September 30 by MichaelC362 3 Quote Link to comment Share on other sites More sharing options...
Mhzayer Posted September 30 Report Share Posted September 30 3 hours ago, MichaelC362 said: I notice the weather location was lost after installing this release... was that intentional? I had the same issue I had to ctrl+f5 to have it back Quote Link to comment Share on other sites More sharing options...
1bit Posted September 30 Report Share Posted September 30 Иookmarks are not synced. This already happened in the previous update. Version 7.2.2.5000 🥺 Quote Link to comment Share on other sites More sharing options...
projektilski Posted September 30 Report Share Posted September 30 Still problems with njuskalo.hr redirecting to perfdrive.com and then asking for a captcha on Maxthon. No other browsers are affected I'm in Croatia, so maybe this affects only users who connect to local internet providers. Also, https://cartechnology.co.uk/ has a captcha that I need to click manually yet Firefox, Chrome, and Edge bypass it automatically. 1 Quote Link to comment Share on other sites More sharing options...
Magdalene Posted September 30 Report Share Posted September 30 @projektilskiTry changing your User Agent. Quote Link to comment Share on other sites More sharing options...
Mhzayer Posted September 30 Report Share Posted September 30 31 minutes ago, projektilski said: Still problems with njuskalo.hr redirecting to perfdrive.com and then asking for a captcha on Maxthon. No other browsers are affected I'm in Croatia, so maybe this affects only users who connect to local internet providers. Also, https://cartechnology.co.uk/ has a captcha that I need to click manually yet Firefox, Chrome, and Edge bypass it automatically. I wasn't redirected went directly to the same address using maxthon UA Chrome/109.0.0.0 Safari/537.36 also for https://cartechnology.co.uk/ I clicked the capcha and it took me to the site Try restarting maxthon in no extensions safe mode Quote Link to comment Share on other sites More sharing options...
projektilski Posted September 30 Report Share Posted September 30 My friend tried Maxthon to access njuskalo.hr and it also was redirected but other browsers do not show that behavior. It seems there is something with Maxthon and also depends on IP address (Croatian internet providers). Cartechnology works yes, but it asks for a captcha every day and I have to click to pass it. It seems Chrome, Egde, Firefox remember it for some time and I don't have to accept it every time, it is accepted automatically. Quote Link to comment Share on other sites More sharing options...
Chemodan Posted September 30 Report Share Posted September 30 4 hours ago, projektilski said: Still problems with njuskalo.hr I went straight to the site, without redirection and without captcha. The second site had captcha. The sites opened in Opera in exactly the same way - the first one straight away, the second one with captcha. Quote Link to comment Share on other sites More sharing options...
BugSir009 Posted October 1 Author Report Share Posted October 1 15 hours ago, MichaelC362 said: I notice the weather location was lost after installing this release... was that intentional? Hi MichaelC362, I could see the location on my end. Could you relaunch your browser and try again? 15 hours ago, MichaelC362 said: Any chance the 'multi-search' feature will ever be added back? Will put in request for the team's consideration Quote Link to comment Share on other sites More sharing options...
BugSir009 Posted October 1 Author Report Share Posted October 1 10 hours ago, 1bit said: Иookmarks are not synced. This already happened in the previous update. Version 7.2.2.5000 🥺 Hi 1bit, were there alot of bookmarks unsync? 10 hours ago, projektilski said: Still problems with njuskalo.hr redirecting to perfdrive.com and then asking for a captcha on Maxthon. No other browsers are affected I'm in Croatia, so maybe this affects only users who connect to local internet providers. Also, https://cartechnology.co.uk/ has a captcha that I need to click manually yet Firefox, Chrome, and Edge bypass it automatically. Hi projektilski, I am able to access both sites on my end. Second site requires clearing of captcha and it works. Quote Link to comment Share on other sites More sharing options...
1bit Posted October 1 Report Share Posted October 1 Hello, BugSir009! I can't synchronize bookmarks and notes on two different computers. Both computers have the same operating system and the same versions of Maxthon. But on one computer, one has new bookmarks, a new bookmark folder structure and, most importantly, notes (!!!), while the other synchronizes some old version from the server. I already asked to restore notes once. After the restoration, everything worked fine. But since the last 3 updates, desynchronization has occurred. What I did: I completely deleted the profile on my home computer and NEW bookmarks and OLD notes were synchronized there. I haven't touched anything on my work computer yet, I'm afraid of losing all my notes. Quote Link to comment Share on other sites More sharing options...
projektilski Posted October 1 Report Share Posted October 1 3 hours ago, BugSir009 said: Hi 1bit, were there alot of bookmarks unsync? Hi projektilski, I am able to access both sites on my end. Second site requires clearing of captcha and it works. Both site work but njuskalo.hr has additional captcha ONLY in Maxthon. Tested on multiple PCs, multiple networks Attached video (it is big, cca 130Mb and it shows two halves of 4k resolution - 2x FullHD) 20241001-0855-35.8037168.mp4 Quote Link to comment Share on other sites More sharing options...
BugSir009 Posted October 1 Author Report Share Posted October 1 3 hours ago, 1bit said: Hello, BugSir009! I can't synchronize bookmarks and notes on two different computers. Both computers have the same operating system and the same versions of Maxthon. But on one computer, one has new bookmarks, a new bookmark folder structure and, most importantly, notes (!!!), while the other synchronizes some old version from the server. I already asked to restore notes once. After the restoration, everything worked fine. But since the last 3 updates, desynchronization has occurred. What I did: I completely deleted the profile on my home computer and NEW bookmarks and OLD notes were synchronized there. I haven't touched anything on my work computer yet, I'm afraid of losing all my notes. Hi 1bit, you could consider to backup a copy of your user data first before you try restoring? Quote Link to comment Share on other sites More sharing options...
Mhzayer Posted October 1 Report Share Posted October 1 1 hour ago, projektilski said: Both site work but njuskalo.hr has additional captcha ONLY in Maxthon. Tested on multiple PCs, multiple networks It's working here fine no captcha after reload I'm on win11 installed version Quote Link to comment Share on other sites More sharing options...
1bit Posted October 1 Report Share Posted October 1 9 hours ago, BugSir009 said: Hi 1bit, you could consider to backup a copy of your user data first before you try restoring? Sure. I exported bookmarks. But I don't know how to export notes. In any case, they can be restored to 09/28/2004. Quote Link to comment Share on other sites More sharing options...
Mhzayer Posted October 1 Report Share Posted October 1 1 hour ago, 1bit said: Sure. I exported bookmarks. But I don't know how to export notes. In any case, they can be restored to 09/28/2004. Copy your userdata folder as a backup Quote Link to comment Share on other sites More sharing options...
projektilski Posted October 2 Report Share Posted October 2 21 hours ago, Mhzayer said: It's working here fine no captcha after reload I'm on win11 installed version Captcha is shown not on the home page but when you search for something. It shows for me and my friend on multiple PCs and OS (Windows 10 and Windows 11) but we are both in Croatia on our major internet providers. Quote Link to comment Share on other sites More sharing options...
Mhzayer Posted October 2 Report Share Posted October 2 3 hours ago, projektilski said: Captcha is shown not on the home page but when you search for something. It shows for me and my friend on multiple PCs and OS (Windows 10 and Windows 11) but we are both in Croatia on our major internet providers. Yes you're right All other browsers like chrome vivaldi firefox and edge have opened the search without asking for captcha 2 minutes ago, Mhzayer said: Yes you're right All other browsers like chrome vivaldi firefox and edge have opened the search without asking for captcha But the site didn't ask for captcha in safe mode It must be an extension I have The extension was Ublock origin after disabling it I could search without a captcha BTW What is this I'm getting Quote Link to comment Share on other sites More sharing options...
grisp1 Posted October 2 Report Share Posted October 2 (edited) Hello @BugSir009 I'm having a bookmark sync issue again with the last few builds—one computer is completely out of sync. Hitting the 'Sync' button starts the process, and no errors are shown, but the changes aren't synced on other PC/Mobile clients. Please advise. Add: Log doesn't show any error but looks weird: [12832:12836:1002/144058.220:INFO:messages_control.cc(2137)] [js_sync] send sync once [12832:12836:1002/144058.220:INFO:mxsyncmgrimpl.cc(809)] starting sync by method `DoSync()` [12832:12836:1002/144058.220:INFO:mxsyncmgrimpl.cc(463)] sync type: 1 Not enabled here. [12832:12836:1002/144058.220:INFO:mxsyncmgrimpl.cc(463)] sync type: 2 Not enabled here. [12832:12836:1002/144058.220:INFO:mxsyncmgrimpl.cc(463)] sync type: 3 Not enabled here. [12832:12836:1002/144058.220:INFO:mxsyncmgrimpl.cc(463)] sync type: 4 Not enabled here. [12832:12836:1002/144058.220:INFO:mxsyncmgrimpl.cc(463)] sync type: 5 Not enabled here. [12832:12836:1002/144058.220:INFO:mxsyncmgrimpl.cc(463)] sync type: 6 Not enabled here. [12832:12836:1002/144058.220:INFO:mxsyncmgrimpl.cc(463)] sync type: 7 Not enabled here. [12832:12836:1002/144058.220:INFO:mxsyncmgrimpl.cc(463)] sync type: 8 Not enabled here. [12832:12836:1002/144058.220:INFO:mxsyncmgrimpl.cc(463)] sync type: 9 Not enabled here. [12832:12836:1002/144058.721:INFO:messages_control.cc(2246)] [js_sync] send event to check dirty and sync [12832:12836:1002/144058.723:INFO:radis_bookmark_control.cc(333)] PushServiceBookmarks length:345253 [12832:20184:1002/144058.724:INFO:mxqasyncImpl.cc(158)] OnGetNewUploadData http://localhost:47602/quickaccess/sync?new=1 [12832:20444:1002/144058.728:INFO:mx_internal_rest_client.cc(336)] http://localhost:47602/quickaccess/sync?new=1 and get data length:385766 [12832:12836:1002/144058.732:INFO:mx_request_control.cc(101)] MxNetRequestCount:0 [12832:12836:1002/144059.566:INFO:web_dialog_manager.cc(1232)] [js_sync] handle newData event with name: bookmarks, ver: 6349 [12832:12836:1002/144059.569:INFO:radis_bookmark_control.cc(333)] PushServiceBookmarks length:345253 Edited October 2 by grisp1 Quote Link to comment Share on other sites More sharing options...
projektilski Posted October 3 Report Share Posted October 3 19 hours ago, Mhzayer said: Yes you're right All other browsers like chrome vivaldi firefox and edge have opened the search without asking for captcha But the site didn't ask for captcha in safe mode It must be an extension I have The extension was Ublock origin after disabling it I could search without a captcha In my case, no, Maxthon causes the issue. I tried a clean portable version without any extension and account, incognito mode, and safe mode. In Maxthon, a captcha is always shown. If you solve the captcha it will not ask for some time. Did you solve the captcha before trying again in safe mode? Quote Link to comment Share on other sites More sharing options...
Mikefon Posted October 3 Report Share Posted October 3 I can't sync with this version. When I try it just keeps trying. It was ok with version 4800. Still I can't sync with Android version 7.4.3.800 with either version (unless I uninstall mobile version and re-install it from scratch). Quote Link to comment Share on other sites More sharing options...
raptorek Posted October 3 Report Share Posted October 3 (edited) No, no, NO!!! After update my notes are empy !!! I lost everything :((( I work on a local profile, I dont log in. By the way - why I must be logged to download video?? Below is floating Download button and information "You must be logged to use this function" but... why? Edited October 3 by raptorek 1 Quote Link to comment Share on other sites More sharing options...
Mhzayer Posted October 3 Report Share Posted October 3 7 hours ago, projektilski said: Did you solve the captcha before trying again in safe mode? Yes If not solved it will ask again even in safe mode BTW BugSir I found an issue with Google Max search If you search for anything that has the symbol & search will ignore anything after it I was trying to search for "j&t express customer service" the search result will only serach for j and ignore anything after it even if you put it between double quotes "j&t express customer service" it will search for "j and ignore the rest Quote Link to comment Share on other sites More sharing options...
projektilski Posted October 3 Report Share Posted October 3 5 hours ago, Mhzayer said: Yes If not solved it will ask again even in safe mode That's my point. Maxthon is the only browser that causes this strange captcha and now I wonder what shady things it does in the background. Quote Link to comment Share on other sites More sharing options...
Join the conversation
