LRRV Posted July 21, 2024 Report Share Posted July 21, 2024 Friends, I have the following problem, in the search engine part I had several, Google, Yahoo, Max/ask among others, after the update I only get Max/ask and it won't let me manually place another one, and if it lets me it won't The search engine works, apart from that the weather does not work either, it does not take the cities, but is placed by country, before it worked by the city I am in, I don't know if it is because of the update that it no longer works or the parameters were changed, Thanks for the help in advance Link to comment Share on other sites More sharing options...
BugSir009 Posted July 22, 2024 Report Share Posted July 22, 2024 On 7/21/2024 at 11:51 AM, LRRV said: Friends, I have the following problem, in the search engine part I had several, Google, Yahoo, Max/ask among others, after the update I only get Max/ask and it won't let me manually place another one, and if it lets me it won't The search engine works, apart from that the weather does not work either, it does not take the cities, but is placed by country, before it worked by the city I am in, I don't know if it is because of the update that it no longer works or the parameters were changed, Thanks for the help in advance Hi LRRV, may I know which version are you using? Link to comment Share on other sites More sharing options...
LRRV Posted July 22, 2024 Author Report Share Posted July 22, 2024 11 hours ago, BugSir009 said: Hi LRRV, may I know which version are you using? Greetings, thank you very much for worrying, I was using version 7.1.7.2001, but it was automatically updated to the new version that I don't remember the number, and from there the errors mentioned appeared, yesterday I installed the beta version 7.2.2.2601 to see if It fixed the errors and it didn't, now errors appear in the history, but that doesn't bother me much, I'm using 64-bit Windows Note: Just updated to Version 7.2.2.3000 (64 bit) 0722 06:58 and the problems continue, when I have time I will uninstall everything and reinstall only the latest version to see if it is resolved Link to comment Share on other sites More sharing options...
Cookie_Monster Posted July 25, 2024 Report Share Posted July 25, 2024 I too noticed the weather widget not working from a few versions ago. Link to comment Share on other sites More sharing options...
