MaxthonJeff Posted June 5 Report Share Posted June 5 7.0.2.2300 beta * Optimize the tab height - Fixed Maxnotes url handing problem - Fixed bookmark opened in wrong position problem - Fixed flashing window when browser started problem https://github.com/maxthon/Maxthon/releases/download/7.0.2.2300/maxthon_7.0.2.2300_beta_x64.exe https://github.com/maxthon/Maxthon/releases/download/7.0.2.2300/maxthon_7.0.2.2300_beta_x86.exe https://github.com/maxthon/Maxthon/releases/download/7.0.2.2300/maxthon_portable_7.0.2.2300_beta_x64.zip https://github.com/maxthon/Maxthon/releases/download/7.0.2.2300/maxthon_portable_7.0.2.2300_beta_x86.zip ??Set your payment address in profile if you have not. Let's reward people who contribute to Maxthon community. ❤️❤️ Click Here ❤️❤️ Link to comment Share on other sites More sharing options...
OPBlackViking Posted June 5 Report Share Posted June 5 Highlight on Caption Button Incorrect position Link to comment Share on other sites More sharing options...
Zura Chelidze Posted June 5 Report Share Posted June 5 Hello everyone, maybe someone knows how to disable secure connection in maxthon.(i mean disable forced redirect from http to https) Link to comment Share on other sites More sharing options...
Ernest44 Posted June 5 Report Share Posted June 5 * Optimize the tab height Where can we access this feature? Link to comment Share on other sites More sharing options...
alexzhus Posted June 5 Report Share Posted June 5 2 hours ago, Zura Chelidze said: Hello everyone, maybe someone knows how to disable secure connection in maxthon.(i mean disable forced redirect from http to https) Hi! Enter mx://net-internals/#hsts Next, go to the tab: Domain Security Policy In the "Delete domain security policies" section, enter the domain name and click on the "Delete" button. Link to comment Share on other sites More sharing options...
Zura Chelidze Posted June 5 Report Share Posted June 5 I can't find it in maxthon this function, this screen from chrome latest version. Link to comment Share on other sites More sharing options...
Mhzayer Posted June 5 Report Share Posted June 5 56 minutes ago, Zura Chelidze said: I can't find it in maxthon this function, this screen from chrome latest version. just go to this mx://net-internals/ you'll find it When updating to this latest version I encountered a previous problem of Maxthon opening all my previously locked tabs blank Link to comment Share on other sites More sharing options...
BugSir009 Posted June 6 Report Share Posted June 6 15 hours ago, OPBlackViking said: Highlight on Caption Button Incorrect position Hi OPBlackViking, have informed the team about this and it will be fixed in next version. 10 hours ago, Ernest44 said: * Optimize the tab height Where can we access this feature? Hi Ernest44, this just implies that the developer has made adjustment to the tab height. Link to comment Share on other sites More sharing options...
BugSir009 Posted June 6 Report Share Posted June 6 7 hours ago, Mhzayer said: When updating to this latest version I encountered a previous problem of Maxthon opening all my previously locked tabs blank Hi Mhzayer, could you check if there is any dump file generated? Link to comment Share on other sites More sharing options...
Chrishall57 Posted June 6 Report Share Posted June 6 Just downloaded 7.0.2.2300 beta, has the 'install as app' function been removed? Thanks Link to comment Share on other sites More sharing options...
MichaelC362 Posted June 6 Report Share Posted June 6 Hello! When placing the cursor over the Customize UI, Minimise, Restore Down & Close buttons, the 'highlight' extends below the icon (using Classic theme): Oops! Didn't see this was already reported! Should read first! Sorry! Link to comment Share on other sites More sharing options...
Mhzayer Posted June 6 Report Share Posted June 6 13 hours ago, BugSir009 said: Hi Mhzayer, could you check if there is any dump file generated? Where exactly would those dump files be? 6 hours ago, Chrishall57 said: Just downloaded 7.0.2.2300 beta, has the 'install as app' function been removed? Thanks Do you mean Link to comment Share on other sites More sharing options...
BugSir009 Posted June 7 Report Share Posted June 7 9 hours ago, Mhzayer said: Where exactly would those dump files be? Hi Mhzayer, kindly go into Task Manager and select 'Details' under the header, search for Maxthon and locate one process that does not have additional parameter. Once located, you could right click on the selected process and click 'Create Dump File' Link to comment Share on other sites More sharing options...
Chrishall57 Posted June 7 Report Share Posted June 7 11 hours ago, Mhzayer said: Where exactly would those dump files be? Do you mean Thanks Mhzayer, I see it now! On other browsers its under settings, couldn't find it on Maxthon Beta. Link to comment Share on other sites More sharing options...
ikingpin Posted June 7 Report Share Posted June 7 If i click open all tab it`s not open. Link to comment Share on other sites More sharing options...
BugSir009 Posted June 7 Report Share Posted June 7 34 minutes ago, ikingpin said: If i click open all tab it`s not open. Hi ikingpin, are you using this latest version 7.0.2.2300? Is this installed or portable version? Link to comment Share on other sites More sharing options...
ikingpin Posted June 7 Report Share Posted June 7 2 hours ago, BugSir009 said: Hi ikingpin, are you using this latest version 7.0.2.2300? Is this installed or portable version? 7.0.2.2300 portable 64 bit Link to comment Share on other sites More sharing options...
BugSir009 Posted June 8 Report Share Posted June 8 15 hours ago, ikingpin said: 7.0.2.2300 portable 64 bit Hi ikingpin, could you try downloading the install version and make sure you do a clean install instead of overwriting the previous version. Link to comment Share on other sites More sharing options...
ikingpin Posted June 8 Report Share Posted June 8 5 hours ago, BugSir009 said: Hi ikingpin, could you try downloading the install version and make sure you do a clean install instead of overwriting the previous version. Not working. Open the last adress in tabs not all. Link to comment Share on other sites More sharing options...
BugSir009 Posted June 8 Report Share Posted June 8 22 minutes ago, ikingpin said: Not working. Open the last adress in tabs not all. Hi ikingpin, I have reported this issue to the development team. This issue will be fixed in the next version. Link to comment Share on other sites More sharing options...
