burianico Posted February 12 Report Share Posted February 12 (edited) Hi, for a few days I have not been able to log in to maxthon passport on maxthon 5 while on maxthon 7 no problem. The error is this: "Login failed (outdated client).(error code 4)". How do I fix it? Thanks. Edited February 12 by burianico 1 Tip Give Link to comment Share on other sites More sharing options...
BugSir009 Posted February 13 Report Share Posted February 13 13 hours ago, burianico said: Hi, for a few days I have not been able to log in to maxthon passport on maxthon 5 while on maxthon 7 no problem. The error is this: "Login failed (outdated client).(error code 4)". How do I fix it? Thanks. Hi burianico, I have already informed the engineers to check on this. Will revert once they find out the issue and managed to resolve it. 1 Tip Give Link to comment Share on other sites More sharing options...
tarabas Posted February 13 Report Share Posted February 13 would love to get this problem solved, too. I need the Maxthon v5 feature to use a browser-based custom proxy setting independent from the system-wide proxy! Tip Give Link to comment Share on other sites More sharing options...
BugSir009 Posted February 20 Report Share Posted February 20 On 2/12/2023 at 10:30 PM, burianico said: Hi, for a few days I have not been able to log in to maxthon passport on maxthon 5 while on maxthon 7 no problem. The error is this: "Login failed (outdated client).(error code 4)". How do I fix it? Thanks. Hi burianico, could you try the login again? The developers has resolved this issue and you should not have any problem logging in. Tip Give Link to comment Share on other sites More sharing options...
burianico Posted February 22 Author Report Share Posted February 22 On 2/20/2023 at 3:02 AM, BugSir009 said: Hi burianico, could you try the login again? The developers has resolved this issue and you should not have any problem logging in. Problem solved, thanks! 1 Tip Give Link to comment Share on other sites More sharing options...
