SirNasso Posted December 30, 2022 Report Share Posted December 30, 2022 Hello, Today on my Huawei Mate 40 pro Maxthon got updated to 7.0.0.4000, and now in the search engine setting there is no Google. And I can't find a way to add it manually. Also after the update on some sites videos wouldn't play, that seems to be fixed upon fresh install. But the search engine setting is not fixed that way. So can you help me with that? Tip Give Link to comment Share on other sites More sharing options...
BugSir009 Posted December 30, 2022 Report Share Posted December 30, 2022 23 minutes ago, SirNasso said: Hello, Today on my Huawei Mate 40 pro Maxthon got updated to 7.0.0.4000, and now in the search engine setting there is no Google. And I can't find a way to add it manually. Also after the update on some sites videos wouldn't play, that seems to be fixed upon fresh install. But the search engine setting is not fixed that way. So can you help me with that? Hi SirNasso, currently android version does not support manual adding of search engine. I will record your request for the development team's consideration. Tip Give Link to comment Share on other sites More sharing options...
SirNasso Posted December 30, 2022 Author Report Share Posted December 30, 2022 Hi BugSir009, It's ok about adding it manually, but the old version had it as an option. The new one doesn't. So if they could just add it back will be great. 1 Tip Give Link to comment Share on other sites More sharing options...
mr.chukcha Posted January 2 Report Share Posted January 2 (edited) Добрый день , 7.0.0.4000 android , вылетает на рабочий стол после просмотра перейти по ссылке любой из яндекса ,гугла итд Good afternoon, 7.0.0.4000 android, the browser crashes to the desktop after trying to follow any link from Yandex, Google, etc. Edited January 2 by mr.chukcha Tip Give Link to comment Share on other sites More sharing options...
BugSir009 Posted January 3 Report Share Posted January 3 16 hours ago, mr.chukcha said: Good afternoon, 7.0.0.4000 android , crashes to the desktop after viewing, follow the link of any of Yandex, Google, etc. Good afternoon, 7.0.0.4000 android, the browser crashes to the desktop after trying to follow any link from Yandex, Google, etc. Hi mr.chukcha, the android version has a few known issues and the developers are trying to fix it before releasing the latest version. Tip Give Link to comment Share on other sites More sharing options...
