ligoten Posted December 3, 2022 Report Share Posted December 3, 2022 I've been stubbornly clinging to Maxthon 5 for quite a while, in part because my favorites are sorted differently in Maxthon 6 than in 5. It looks like Maxthon 6 might be sorting entries from newest to oldest, while Maxthon 5 has them oldest to newest, except where I have manually moved items around. Is it possible to make Maxthon 6 follow my existing favorites order instead of re-sorting? Tip Give Link to comment Share on other sites More sharing options...
BugSir009 Posted December 5, 2022 Report Share Posted December 5, 2022 On 12/3/2022 at 12:47 PM, ligoten said: I've been stubbornly clinging to Maxthon 5 for quite a while, in part because my favorites are sorted differently in Maxthon 6 than in 5. It looks like Maxthon 6 might be sorting entries from newest to oldest, while Maxthon 5 has them oldest to newest, except where I have manually moved items around. Is it possible to make Maxthon 6 follow my existing favorites order instead of re-sorting? Hi ligoten, you may choose to import MX5 data over to MX6. Imported bookmarks will be in a new folder and these bookmarks will not be affected. In MX6 the bookmarks sequence is still being determined on the date and time created. Tip Give Link to comment Share on other sites More sharing options...
ligoten Posted December 5, 2022 Author Report Share Posted December 5, 2022 10 hours ago, BugSir009 said: Hi ligoten, you may choose to import MX5 data over to MX6. Imported bookmarks will be in a new folder and these bookmarks will not be affected. In MX6 the bookmarks sequence is still being determined on the date and time created. I've tried that multiple times, choosing to overwrite the Maxthon 6 local and server data with the Maxthon 5 server data. Hmm, it seems that the problem is that the Maxthon 5 server data is in a different order than my local data. Or at least, my local favorites list is different than opening Maxnote. How did that happen? Tip Give Link to comment Share on other sites More sharing options...
BugSir009 Posted December 6, 2022 Report Share Posted December 6, 2022 6 hours ago, ligoten said: I've tried that multiple times, choosing to overwrite the Maxthon 6 local and server data with the Maxthon 5 server data. Hmm, it seems that the problem is that the Maxthon 5 server data is in a different order than my local data. Or at least, my local favorites list is different than opening Maxnote. How did that happen? Hi ligoten, bookmarks is different from MaxNote. Once you have imported the data, the bookmarks will show at the address bar and side bar while for MaxNote you will have to access it from the main menu at the top right hand corner or alternatively press ALT + Shift + N Tip Give Link to comment Share on other sites More sharing options...
ligoten Posted December 6, 2022 Author Report Share Posted December 6, 2022 But my favorites in Maxthon 6 are in a different order than my favorites in Maxthon 5, and look more like the Maxnote Bookmarks folder. Tip Give Link to comment Share on other sites More sharing options...
BugSir009 Posted December 6, 2022 Report Share Posted December 6, 2022 9 minutes ago, ligoten said: But my favorites in Maxthon 6 are in a different order than my favorites in Maxthon 5, and look more like the Maxnote Bookmarks folder. Hi ligoten, could you provide screenshots so we could look into it? Tip Give Link to comment Share on other sites More sharing options...
ligoten Posted December 6, 2022 Author Report Share Posted December 6, 2022 Snippets of the favorites in 5 and 6. Tip Give Link to comment Share on other sites More sharing options...
BugSir009 Posted December 6, 2022 Report Share Posted December 6, 2022 2 hours ago, ligoten said: Snippets of the favorites in 5 and 6. Hi ligoten, you may go under Settings > General > Open your account local folder and click Profile > Backups > Bookmarks. Select one of the backup file and replace your local bookmark file with it. Tip Give Link to comment Share on other sites More sharing options...
ligoten Posted December 6, 2022 Author Report Share Posted December 6, 2022 34 minutes ago, BugSir009 said: Hi ligoten, you may go under Settings > General > Open your account local folder and click Profile > Backups > Bookmarks. Select one of the backup file and replace your local bookmark file with it. Okay, I've done that and the sort order is still different, but now more recent changes are missing. Tip Give Link to comment Share on other sites More sharing options...
BugSir009 Posted December 6, 2022 Report Share Posted December 6, 2022 1 hour ago, ligoten said: Okay, I've done that and the sort order is still different, but now more recent changes are missing. Hi ligoten, could you provide your Maxthon account ID and email so we could do a further check for you? Tip Give Link to comment Share on other sites More sharing options...
ligoten Posted December 6, 2022 Author Report Share Posted December 6, 2022 As far as I know, my Maxthon account ID is the same as my ID here: ligoten. My email is ligoten@gmail.com. Tip Give Link to comment Share on other sites More sharing options...
BugSir009 Posted December 6, 2022 Report Share Posted December 6, 2022 1 hour ago, ligoten said: As far as I know, my Maxthon account ID is the same as my ID here: ligoten. My email is ligoten@gmail.com. Hi ligoten, the server only has one 2021 version of your bookmarks stored. Could you try importing Maxthon 5 account data again under MX6 settings? I will get the engineers to check again once you are done. Tip Give Link to comment Share on other sites More sharing options...
ligoten Posted December 6, 2022 Author Report Share Posted December 6, 2022 Just imported again. Tip Give Link to comment Share on other sites More sharing options...
BugSir009 Posted December 6, 2022 Report Share Posted December 6, 2022 53 minutes ago, ligoten said: Just imported again. Hi ligoten, could you go to your User Data/ Log files and send today's file to me? The engineers are trying to look into the issue. Tip Give Link to comment Share on other sites More sharing options...
ligoten Posted December 6, 2022 Author Report Share Posted December 6, 2022 Here: 20221206.logmxservice.log Tip Give Link to comment Share on other sites More sharing options...
BugSir009 Posted December 6, 2022 Report Share Posted December 6, 2022 15 minutes ago, ligoten said: Here: 20221206.log 678.06 kB · 0 downloads mxservice.log 1.38 kB · 0 downloads Hi ligoten, engineers looked through your log files and seems like there were connection error while you tried to import. Did you set DNS or extend network? Tip Give Link to comment Share on other sites More sharing options...
ligoten Posted December 6, 2022 Author Report Share Posted December 6, 2022 I'm not sure what you mean by extend network, but DNS and DHCP are both being automatically configured. I also am not using a VPN. Tip Give Link to comment Share on other sites More sharing options...
BugSir009 Posted December 6, 2022 Report Share Posted December 6, 2022 36 minutes ago, ligoten said: I'm not sure what you mean by extend network, but DNS and DHCP are both being automatically configured. I also am not using a VPN. How about extensions? Do you have any extensions that could possibly interrupt with the syncing? Could you disable all extensions and try again? Tip Give Link to comment Share on other sites More sharing options...
ligoten Posted December 6, 2022 Author Report Share Posted December 6, 2022 For these tests, I've been using a fresh portable Maxthon 6 (x64) with no added extensions. Tip Give Link to comment Share on other sites More sharing options...
BugSir009 Posted December 6, 2022 Report Share Posted December 6, 2022 55 minutes ago, ligoten said: For these tests, I've been using a fresh portable Maxthon 6 (x64) with no added extensions. Hi ligoten, are you open to debug this issue remotely? AnyDesk.exe Tip Give Link to comment Share on other sites More sharing options...
ligoten Posted December 6, 2022 Author Report Share Posted December 6, 2022 I suppose we could try. Tip Give Link to comment Share on other sites More sharing options...
