LifeBunny 0 Posted April 30, 2013 Report Share Posted April 30, 2013 Hello! I have problem with player buttons How they are like this?? Link to post Share on other sites
17302342 0 Posted April 30, 2013 Report Share Posted April 30, 2013 switch off ultra mode - to classic. Link to post Share on other sites
Golfmann 46 Posted April 30, 2013 Report Share Posted April 30, 2013 that's the only way it gets fixed on mine, too Link to post Share on other sites
joemax 100 Posted April 30, 2013 Report Share Posted April 30, 2013 Which versions are you guys using? I don't have that problem, and maybe which User Agent are you using? Edit: Are you using any scripts that could affect the appearance? Link to post Share on other sites
BugSir 0 Posted May 2, 2013 Report Share Posted May 2, 2013 Hey,did you try out the latest version http://forum.maxthon.com/forum.php?mod=viewthread&tid=1694 .For me it work fine ... Link to post Share on other sites
kvreddy 0 Posted May 2, 2013 Report Share Posted May 2, 2013 i am not getting any problem to watch video in the youtube..... only the problem in the youtube is.... youtube icon and search option.... Link to post Share on other sites
mert41994 3 Posted May 13, 2013 Report Share Posted May 13, 2013 I can't see them. How Can i fix it? I'm using last update. Thanks everyone Link to post Share on other sites
-ody- 1,233 Posted May 13, 2013 Report Share Posted May 13, 2013 mert41994 replied at 2013-5-13 10:41 I can't see them. How Can i fix it? I'm using last update. did you try to switch to retro mode ? Link to post Share on other sites
WDS555 0 Posted May 13, 2013 Report Share Posted May 13, 2013 Hi guys! Same problem... I'd tried switch to retro mode. Works but the ads hunter turned off while switched at this mode. Any suggestion??? Thanks. Link to post Share on other sites
mert41994 3 Posted May 15, 2013 Report Share Posted May 15, 2013 odyssee replied at 2013-5-13 11:22 did you try to switch to retro mode ? Sorry, i haven't seen it :/ And i'm not using retro mod. Link to post Share on other sites
-ody- 1,233 Posted May 15, 2013 Report Share Posted May 15, 2013 at the moment adhunter is off in retro, switching to retro is the best workaround I close this thread, please go to this one to post http://forum.maxthon.com/forum.php?mod=redirect&goto=findpost&ptid=1450&pid=13308&fromuid=6887800 Link to post Share on other sites
17631156 0 Posted June 18, 2013 Report Share Posted June 18, 2013 When on YouTube the AdHunter extension blocks the image of the search button, the YouTube logo/home button, and some other things it shouldn't, I've added these to the white-list but it did nothing, how do I go about fixing this? Also, how do I get rid of the previous page button? I keep on mistaking it for the refresh button. xD Link to post Share on other sites
joemax 100 Posted June 18, 2013 Report Share Posted June 18, 2013 Hi, and welcome to the forum Are you sure that they are being blocked by adhunter? Please update to the latest forum version which addresses this error. Please be reminded to search before starting new threads, a search for "Youtube" would have found a number of threads relating to this problem. TIA Link to post Share on other sites
17631156 0 Posted June 18, 2013 Report Share Posted June 18, 2013 I changed the UA setting to Opera, that worked for me. To do this: 1. go to options 2. go to advanced 3. check the box that says "custom UserAgent string" 4. change to opera from the drop down menu Link to post Share on other sites
Imanerd 24 Posted June 26, 2013 Report Share Posted June 26, 2013 kvreddy replied at 2013-5-2 06:34 i am not getting any problem to watch video in the youtube..... except update checker only checks final versions. look closely, please, at where your screenshot says 4.0.5.400, and the release to which a link was given by BugSir, says 4.0.6.1900 Beta. Thanks in advance. Might fix the problem. Link to post Share on other sites
Imanerd 24 Posted June 26, 2013 Report Share Posted June 26, 2013 joemax replied at 2013-6-18 11:27 Hi, and welcome to the forum Are you sure that they are being blocked by adhunter? Please update ... it's because of Google's switch to WebP image format, so Maxthon doesn't support those, as I've read elsewhere on these forums. It's not by adhunter, tested and confirmed. Heck, it happened within one particular night and I hadn't changed any youtube adhunter rules in between that time. disabling has no effect. Yes, UA controls what the site thinks you are using, thus fooling it into displaying certain elements that are not shown otherwise, however, Google runs Chrome from Chromium open source of course, so Chromium no doubt supports WebP images. That having been said, if you change it to another UA, it might work in theory, but I have a custom UA as Maxthon, which almsot all sites think is Chrome. If Chrome supports WebP, then I'd have no problem displaying it, yet I do. In this case, it's not a matter of the site displaying content based on a spoofed or unspoofed browser type, but an unsupported format in the webkit file(s). At least, this is to the best of my knowledge. I will switch to Opera UA for a moment, and let everyone know if it works, nevertheless. edit: actually you're correct, it does fix it. Weird. Can't explain this, unless I have misread or dreamt a post on the forum regarding unsupported WebP images, or if it might have been wrong. And since when did iPad show up as a possible custom UA. I go in there all the time, and I've NEVER seen it. Perhaps I'm losing my sanity. It bothers me, but I haven't said anything because it's not a big deal to me, personally, and because it's already been posted elsewhere, anyway. Like joemax says, please use the search function before posting an issue, because it might be there already somewhere. Link to post Share on other sites
