gazumba Posted July 25 Report Share Posted July 25 In my company I use Maxthon logged as Guest. In the last three releases, the User Data folder seems to be corrupted. When I start Maxthon, every time I need to (re-)enter as Guest in the box, and all data that I saved before is lost. As I can not sign in Maxthon account due to company's restrictions, I was forced to back to 6.1.3.3400. This release is running OK. Tip Give Link to comment Share on other sites More sharing options...
BugSir006 Posted July 26 Report Share Posted July 26 8 hours ago, gazumba said: In my company I use Maxthon logged as Guest. In the last three releases, the User Data folder seems to be corrupted. When I start Maxthon, every time I need to (re-)enter as Guest in the box, and all data that I saved before is lost. Hi gazumba, you mean the folder "User Data" can work normally under the version 6.1.3.3400 but the latest version 6.2.0.600 cannot display the user data? 8 hours ago, gazumba said: As I can not sign in Maxthon account due to company's restrictions, I was forced to back to 6.1.3.3400. This release is running OK. You mean you cannot log in to your browser account in version 6.2.0.600, but you can log in to your browser account in version 6.1.3.3400? Tip Give Link to comment Share on other sites More sharing options...
gazumba Posted July 26 Author Report Share Posted July 26 9 hours ago, BugSir006 said: Hi gazumba, you mean the folder "User Data" can work normally under the version 6.1.3.3400 but the latest version 6.2.0.600 cannot display the user data? You mean you cannot log in to your browser account in version 6.2.0.600, but you can log in to your browser account in version 6.1.3.3400? No. I can not sign in in all Maxthon versions. But, the last version I could use without problems was 6.1.3.3400. In versions after that, the login popup appears all time I run Maxthon and, worse, all my "Guest" customizations are lost. Then, I backed up the folder "User Data" everytime I tryed to update the browser in order to test new version. In all cases, starting with 6.2.0.500, the user data was corrupted. In time: I am using PORTABLE, due to a company's restrictions and I can not provide screens. Tip Give Link to comment Share on other sites More sharing options...
BugSir006 Posted July 27 Report Share Posted July 27 16 hours ago, gazumba said: No. I can not sign in in all Maxthon versions. But, the last version I could use without problems was 6.1.3.3400. In versions after that, the login popup appears all time I run Maxthon and, worse, all my "Guest" customizations are lost. Then, I backed up the folder "User Data" everytime I tryed to update the browser in order to test new version. In all cases, starting with 6.2.0.500, the user data was corrupted. In time: I am using PORTABLE, due to a company's restrictions and I can not provide screens. Hi gazumba, please use the attached test version to test the issues. Regarding the login issue, please check if it has any prompt window in this version; if it doesn't have the prompt window, please open mx://inner_test to check it, snap the screenshot, and then send it to me. Please send the log file to me. ? mx_6.2.0.600_0726.zip Tip Give Link to comment Share on other sites More sharing options...
gazumba Posted July 27 Author Report Share Posted July 27 (edited) Hi! Same! I changed to version above and my data was corrupted. I am attaching two images. In the first execution, MX6 runs fine. In the second one, the login popup appeared. Then, after choose to log as guest, my initial screen with my main favorites changed to a standard page, as showed in antother attached image. Edited July 27 by gazumba Tip Give Link to comment Share on other sites More sharing options...
BugSir006 Posted July 28 Report Share Posted July 28 12 hours ago, gazumba said: Hi! Same! I changed to version above and my data was corrupted. I am attaching two images. In the first execution, MX6 runs fine. In the second one, the login popup appeared. Then, after choose to log as guest, my initial screen with my main favorites changed to a standard page, as showed in antother attached image. Could we debug this issue remotely via AnyDesk? AnyDesk.exe Tip Give Link to comment Share on other sites More sharing options...
gazumba Posted July 28 Author Report Share Posted July 28 10 hours ago, BugSir006 said: Could we debug this issue remotely via AnyDesk? AnyDesk.exe 3.04 MB · 0 downloads Unfortunately I can not debug. As I wrote previously, I am over company's restrictions. Firewall, rules to run applications out of a list, etc. Tip Give Link to comment Share on other sites More sharing options...
BugSir006 Posted July 29 Report Share Posted July 29 11 hours ago, gazumba said: Unfortunately I can not debug. As I wrote previously, I am over company's restrictions. Firewall, rules to run applications out of a list, etc. Regarding the login issue, please check if it has any prompt window in this attached test version; if it doesn't have the prompt window, please open mx://inner_test to check it, snap the screenshot, and then send it to me. Please send the log file to me. ? It would be appreciated if you can provide a short video of this issue. mx_6.2.0.600_0726.zip Tip Give Link to comment Share on other sites More sharing options...
gazumba Posted August 3 Author Report Share Posted August 3 Tested. The problem "remains the same"... (sorry, Led Zeppelin) Tip Give Link to comment Share on other sites More sharing options...
BugSir006 Posted August 4 Report Share Posted August 4 16 hours ago, gazumba said: Tested. The problem "remains the same"... (sorry, Led Zeppelin) Could you please provide a short video or screenshot? Please open "mx://inner_test" and snap the screenshot. Tip Give Link to comment Share on other sites More sharing options...
