scottchu.tw Posted June 14 Report Share Posted June 14 (edited) Previously I install simple copy on Chrome Web store. But I worry about it is incomaptible with MX6 and cause problem. I hope MX6 web store can provide an extension of similar functions as simple copy. Edited June 14 by scottchu.tw Tip Give Link to comment Share on other sites More sharing options...
BugSir006 Posted June 14 Report Share Posted June 14 Hi scottchu.tw, if you experience any issues when using the extension "Allow right click - simple copy" please describe the issue in detail or provide a short video of it. The dev team will analyze and fix it as soon as possible. Tip Give Link to comment Share on other sites More sharing options...
BugSir009 Posted June 15 Report Share Posted June 15 17 hours ago, scottchu.tw said: Previously I install simple copy on Chrome Web store. But I worry about it is incomaptible with MX6 and cause problem. I hope MX6 web store can provide an extension of similar functions as simple copy. Hi scottchu.tw, currently we do not have this simple copy extension in MX6 web store. You could download from Chrome web store and it is usually compatible. If after installing a particular extension and you noticed possible bugs, do let us know and we can ask the development team to fix it. Tip Give Link to comment Share on other sites More sharing options...
scottchu.tw Posted June 15 Author Report Share Posted June 15 Ok, thanks! Tip Give Link to comment Share on other sites More sharing options...
