Ben.L.Salomon Posted March 15 Report Share Posted March 15 Hi Im from Czech Republic and 8.3.2022 HBO max started work in our country. But on Maxthon broswer not working. When you click on play will appear error "Make sure your browser is not in private browsing mode" 1. Not using incognito mode 2. Clear cookies 3. Disable AdBlock 4. Using last ver. 6.1.3.1900 Nothing helped. Andy ideas ? Thank you Tip Give Link to comment Share on other sites More sharing options...
BugSir006 Posted March 15 Report Share Posted March 15 Hi Ben.L.Salomon, how about other browsers? Could you provide the specific URL of this issue? Tip Give Link to comment Share on other sites More sharing options...
Ben.L.Salomon Posted March 15 Author Report Share Posted March 15 Other browsers works normal like Edge. Just Maxthon not. Here for example https://play.hbomax.com/feature/urn:hbo:feature:GYeB2LgKJ1cIOjAEAAABQ Tip Give Link to comment Share on other sites More sharing options...
Magdalene Posted March 15 Report Share Posted March 15 Try using a VPN. Tip Give Link to comment Share on other sites More sharing options...
Ben.L.Salomon Posted March 15 Author Report Share Posted March 15 VPN does not fix the problem Tip Give Link to comment Share on other sites More sharing options...
BugSir006 Posted March 16 Report Share Posted March 16 20 hours ago, Ben.L.Salomon said: Other browsers works normal like Edge. Just Maxthon not. Here for example https://play.hbomax.com/feature/urn:hbo:feature:GYeB2LgKJ1cIOjAEAAABQ Bug reported. 😊 Tip Give Link to comment Share on other sites More sharing options...
Magdalene Posted March 16 Report Share Posted March 16 Quote VPN does not fix the problem It's a bug in the browser then. Tip Give Link to comment Share on other sites More sharing options...
Ben.L.Salomon Posted March 18 Author Report Share Posted March 18 Lets hope for early fix Tip Give Link to comment Share on other sites More sharing options...
