Jus2021 Posted December 30, 2021 Report Share Posted December 30, 2021 Hello, I am using Mx v.6.1.3.901 portable. I had a strange problem, not only with this version but some versions before: When I am using the browser in the normal way, everything is working fine as long as I am not opening the links from others programs. But when I tried to open the links from other programs (where Maxthon is set as default browser), all the tabs' contents went blank. To make them appeared again, I had to minimize the browser first and restore it (for more details, see the video). Am I missing something? Jus Maxthonbug1.mp4 Link to comment Share on other sites More sharing options...
BugSir009 Posted December 31, 2021 Report Share Posted December 31, 2021 16 hours ago, Jus2021 said: Hello, I am using Mx v.6.1.3.901 portable. I had a strange problem, not only with this version but some versions before: When I am using the browser in the normal way, everything is working fine as long as I am not opening the links from others programs. But when I tried to open the links from other programs (where Maxthon is set as default browser), all the tabs' contents went blank. To make them appeared again, I had to minimize the browser first and restore it (for more details, see the video). Am I missing something? Jus Maxthonbug1.mp4 Hi Jus2021, could you disable all extensions and try again? Do you have the MX6 install version in local? Could you also provide us with your system information? Link to comment Share on other sites More sharing options...
Jus2021 Posted December 31, 2021 Author Report Share Posted December 31, 2021 Thank you for your reply. I will try your solution and come back to you. Link to comment Share on other sites More sharing options...
Jus2021 Posted January 3, 2022 Author Report Share Posted January 3, 2022 Hello BurgSir 009, I tried to disable all the extensions, the problem remained. I use MX6 portable not the install version. My system is Windows 10 64bits. Link to comment Share on other sites More sharing options...
BugSir006 Posted January 4, 2022 Report Share Posted January 4, 2022 12 hours ago, Jus2021 said: Hello BurgSir 009, I tried to disable all the extensions, the problem remained. I use MX6 portable not the install version. My system is Windows 10 64bits. Jus2021, could you please try this issue again in the latest version 6.1.3.1000? Link to comment Share on other sites More sharing options...
Jus2021 Posted January 4, 2022 Author Report Share Posted January 4, 2022 Hello BurgSir006, I did, but the problem continued. I did not notice this before because MX6 was not and still not my default browser. So I started to test MX6 as a default browser in flew programs instead of the “copy and paste” of the links before making it the default browser for my computer. Link to comment Share on other sites More sharing options...
BugSir006 Posted January 5, 2022 Report Share Posted January 5, 2022 On 1/4/2022 at 7:13 PM, Jus2021 said: Hello BurgSir006, I did, but the problem continued. I did not notice this before because MX6 was not and still not my default browser. So I started to test MX6 as a default browser in flew programs instead of the “copy and paste” of the links before making it the default browser for my computer. Hi Jus2021, thank you for your reply. This issue has been reported to the dev team. ? Link to comment Share on other sites More sharing options...
BugSir006 Posted January 7, 2022 Report Share Posted January 7, 2022 Hi Jus2021, this issue has been fixed in our internal version, could you please test it in this version? Link to comment Share on other sites More sharing options...
Jus2021 Posted January 7, 2022 Author Report Share Posted January 7, 2022 Hello BurgSir006, I will try it Link to comment Share on other sites More sharing options...
Jus2021 Posted January 8, 2022 Author Report Share Posted January 8, 2022 This test installer version seems working. I will now try the new installer version Mx_6.1.3.1100_beta_x64 and the portable version. Link to comment Share on other sites More sharing options...
Jus2021 Posted January 10, 2022 Author Report Share Posted January 10, 2022 The portable version is working fine. Thank you developers Link to comment Share on other sites More sharing options...
