nogain Posted September 8, 2021 Report Share Posted September 8, 2021 I don't want to use synchronization because it is not selective, I would like to know which files or folders I need to backup to keep magic fill passwords and general browser settings. Thanks Maxthon 6.1.2.2700 Tip Give Link to comment Share on other sites More sharing options...
BugSir009 Posted September 9, 2021 Report Share Posted September 9, 2021 10 hours ago, nogain said: I don't want to use synchronization because it is not selective, I would like to know which files or folders I need to backup to keep magic fill passwords and general browser settings. Thanks Maxthon 6.1.2.2700 Hi nogain, you could backup the User Data folder for the password and settings. Tip Give Link to comment Share on other sites More sharing options...
nogain Posted September 9, 2021 Author Report Share Posted September 9, 2021 12 hours ago, BugSir009 said: Hi nogain, you could backup the User Data folder for the password and settings. Thanks, I had imagined it, while for the Magic Fill passwords only, the files of which these folders should I take? Tip Give Link to comment Share on other sites More sharing options...
BugSir009 Posted September 10, 2021 Report Share Posted September 10, 2021 11 hours ago, nogain said: Thanks, I had imagined it, while for the Magic Fill passwords only, the files of which these folders should I take? Hi nogain, you could use our cloud backup in uu.me. Just sign in to uu.me and go under Passkeeper. Tip Give Link to comment Share on other sites More sharing options...
nogain Posted September 10, 2021 Author Report Share Posted September 10, 2021 7 hours ago, BugSir009 said: Hi nogain, you could use our cloud backup in uu.me. Just sign in to uu.me and go under Passkeeper. Hi BugSir009, I could but I would also like to know how to do it manually as I did with Maxthon 5. There, I synchronized everything except the passwords that I managed manually with the file Tip Give Link to comment Share on other sites More sharing options...
BugSir009 Posted September 10, 2021 Report Share Posted September 10, 2021 22 minutes ago, nogain said: Hi BugSir009, I could but I would also like to know how to do it manually as I did with Maxthon 5. There, I synchronized everything except the passwords that I managed manually with the file Hi nogain, it seems that there were a few accounts in the screenshot you sent to us. It would be best if you were to backup all the folders. Tip Give Link to comment Share on other sites More sharing options...
nogain Posted September 10, 2021 Author Report Share Posted September 10, 2021 1 hour ago, BugSir009 said: Hi nogain, it seems that there were a few accounts in the screenshot you sent to us. It would be best if you were to backup all the folders. Ok BugSir009, thank you for support. I hope selective syncing is introduced someday. Tip Give Link to comment Share on other sites More sharing options...
