jugurtha 5 Posted April 17, 2020 Report Share Posted April 17, 2020 Hi, I am facing a problem after the last Windows 10 update, text and images appear strange. Link to post Share on other sites
jugurtha 5 Posted April 18, 2020 Author Report Share Posted April 18, 2020 the same problem on maxthon 6 alpha i uninstalled and installed maxthon 5 and 6 but the same problem. Link to post Share on other sites
Magdalene 183 Posted April 19, 2020 Report Share Posted April 19, 2020 This is a Windows 10 problem. In Windows go to "Settings", then "Display". Under "Scale and Layout", click on "Advanced scale settings". Under "Fix Scaling for apps" turn on "Let windows try to fix apps so they're not blurry". Link to post Share on other sites
jugurtha 5 Posted April 19, 2020 Author Report Share Posted April 19, 2020 3 hours ago, Magdalene said: This is a Windows 10 problem. In Windows go to "Settings", then "Display". Under "Scale and Layout", click on "Advanced scale settings". Under "Fix Scaling for apps" turn on "Let windows try to fix apps so they're not blurry". Thanks, it is fixed😊 Link to post Share on other sites
