DARKSTORM Posted April 16 Report Share Posted April 16 Is the Reading View not yet integrated? I remember there is a way to activate it but forgot how. Tip Give Link to comment Share on other sites More sharing options...
leeuniverse Posted April 27 Report Share Posted April 27 (edited) On 3/20/2022 at 2:40 AM, Massor said: A little off topic. What will happen with MX6 Retro mode when Microsoft retires IE? It will still work? I suspect as long as IE remains in Windows it will continue to be used. Eventually when IE falls out of need/usage they will likely just use "Edge" as the secondary since it will be the browser installed with Windows going forward? Edited April 27 by leeuniverse Tip Give Link to comment Share on other sites More sharing options...
Massor Posted May 1 Report Share Posted May 1 (edited) Very nice the new History page, more compact, more useful. Just a little thing: can the tree with the date in the left to be a little indented with few pixels, individual days from the month root? It will be more easy to read and to follow. Edited May 1 by Massor Tip Give Link to comment Share on other sites More sharing options...
BugSir009 Posted May 4 Report Share Posted May 4 On 5/1/2022 at 4:11 PM, Massor said: Very nice the new History page, more compact, more useful. Just a little thing: can the tree with the date in the left to be a little indented with few pixels, individual days from the month root? It will be more easy to read and to follow. Hi Massor, request recorded. Tip Give Link to comment Share on other sites More sharing options...
kvd71 Posted May 11 Report Share Posted May 11 6.1.3.2650(64 бит)0509 Tip Give Link to comment Share on other sites More sharing options...
BugSir006 Posted May 11 Report Share Posted May 11 49 minutes ago, kvd71 said: 6.1.3.2650(64 бит)0509 Hi kvd71, could you please describe the operating steps that caused this issue? Tip Give Link to comment Share on other sites More sharing options...
Sergey_K Posted Thursday at 01:37 PM Report Share Posted Thursday at 01:37 PM There is a problem with playing videos from youtube in HD1080 quality in AVC1 codec format . When you hover the mouse cursor over the video (when the status bar appears), it starts to slow down terribly (freeze). The same thing happens if you press pause and then start the video again. At the same time, there is a significant loss of frames - (Statistics for sysadmins - the Viewport/Frames parameter "dropped"). If the video is in VP09 format, then this does not happen. Here is an example of such a video (you need to watch it from Youtube): P.S.: Windows 7 64bit; Maxthon 6 is the latest version, but the problem has been observed for a long time, there just wasn't time to write here. 1 Tip Give Link to comment Share on other sites More sharing options...
alexzhus Posted Thursday at 02:38 PM Report Share Posted Thursday at 02:38 PM 1 hour ago, Sergey_K said: There is a problem with playing videos from youtube in HD1080 quality in AVC1 codec format . When you hover the mouse cursor over the video (when the status bar appears), it starts to slow down terribly (freeze). The same thing happens if you press pause and then start the video again. At the same time, there is a significant loss of frames - (Statistics for sysadmins - the Viewport/Frames parameter "dropped"). If the video is in VP09 format, then this does not happen. Here is an example of such a video (you need to watch it from Youtube): P.S.: Windows 7 64bit; Maxthon 6 is the latest version, but the problem has been observed for a long time, there just wasn't time to write here. Try to disable the items indicated on the screenshot and check. Helped me. chrome://flags/#disable-accelerated-video-decode chrome://flags/#disable-accelerated-video-encode 2 Tip Give Link to comment Share on other sites More sharing options...
Sergey_K Posted Thursday at 05:02 PM Report Share Posted Thursday at 05:02 PM alexzhus Yes, it works, the video is no longer freezing! Thank you very much for your help! PS: can you explain - these functions disable video decoding by my video card and enable software decoding? Tip Give Link to comment Share on other sites More sharing options...
