Maxion Posted August 28, 2018 Report Share Posted August 28, 2018 I run portable Maxthon on a PC that also has IE 11. I changed the default browser setting to Maxthon, but now I cannot reverse it! The entry in Maxthon's settings is greyed out and resetting everything to default does not correct this setting. IE runs on this PC with certain restrictions and I cannot make IE the default browser through its own settings. I would appreciate any ideas on how to revert to IE being the default browser. Link to comment Share on other sites More sharing options...
pantantrollo Posted August 28, 2018 Report Share Posted August 28, 2018 I would tell you to install other browsers that would then let you exclude yourself from not being the default browser, but if you have the problem with the IE11's restrictions to default, you may get stuck in them. Look for some third party utility that allows you to choose default browser, until some years ago there was some way for here Link to comment Share on other sites More sharing options...
7twenty Posted August 28, 2018 Report Share Posted August 28, 2018 3 hours ago, Maxion said: The entry in Maxthon's settings is greyed out That's just a notification. You need to uncheck the boxes to disable it. Link to comment Share on other sites More sharing options...
BugMeNope Posted August 28, 2018 Report Share Posted August 28, 2018 Interestingly, on my portable Maxthon I do not see the second checkbox. Link to comment Share on other sites More sharing options...
pantantrollo Posted August 28, 2018 Report Share Posted August 28, 2018 3 hours ago, BugMeNope said: Interestingly, on my portable Maxthon I do not see the second checkbox. Version 5.2.4.2000 Portable Link to comment Share on other sites More sharing options...
rick.lane Posted August 28, 2018 Report Share Posted August 28, 2018 10 hours ago, Maxion said: IE runs on this PC with certain restrictions and I cannot make IE the default browser through its own settings. I would appreciate any ideas on how to revert to IE being the default browser. Are you on Win10? Try going to Windows Settings>Apps>Default apps and scroll down to Web browser. Click on the entry for browser and you should see a list of available choices. IE should be one of them. Select that and see what happens. Link to comment Share on other sites More sharing options...
Maxion Posted August 29, 2018 Author Report Share Posted August 29, 2018 19 hours ago, BugMeNope said: Interestingly, on my portable Maxthon I do not see the second checkbox. Hmm... Same here. Anyway, I solved the problem by the most direct way possible. I changed the default browser setting in Internet Explorer and everything is fine now. Link to comment Share on other sites More sharing options...
7twenty Posted August 29, 2018 Report Share Posted August 29, 2018 22 hours ago, BugMeNope said: Interestingly, on my portable Maxthon I do not see the second checkbox. Must be using an older version. At least from 5.2.4.x there are two options. Link to comment Share on other sites More sharing options...
Maxion Posted August 29, 2018 Author Report Share Posted August 29, 2018 I installed portable Maxthon on a friend's PC and it does have the two check boxes. I must conclude that the first installation that I did didn't go right and I ended up with only the one check box. Link to comment Share on other sites More sharing options...
7twenty Posted August 30, 2018 Report Share Posted August 30, 2018 20 hours ago, Maxion said: the first installation that I did didn't go right and I ended up with only the one check box. There's nothing you can do wrong when installing that can cause a missing checkbox. I'm pretty sure you installed an older version. Link to comment Share on other sites More sharing options...
Maxion Posted August 30, 2018 Author Report Share Posted August 30, 2018 Please note that I had installed v. 5.2.3.6000. Link to comment Share on other sites More sharing options...
