MrChat Posted September 25, 2017 Report Share Posted September 25, 2017 Hi I recently found some weird issue when I was trying to upgrade to 5.1.2.X branch, basically installer was reaching 64% and then just close itself without actually doing anything. To try and fix it I completely uninstalled Maxthon and now it is very strange: 1. All versions 5.1.2.100.beta, 5.1.2.200-beta and 5.1.2.1000. When trying to install them, the installer show progress till 64% and then installer disappears. I checked in Program Files (x86) folder, Maxthon folder not even created there. 2. When trying to run installer as administrator, the installation runs fully and all folders created (even though for some odd reason maxthon got installed into C:\Program Files (x86)\Maxthon5\5.1.2.200\5.1.2.1000), however getting error maxthon_install_error.PNG. 3. When trying to open Maxthon after installed as administrator I'm getting error maxthon_launch_error.png 4. I uninstalled it again and installed version 5.1.1.1000 (without being administrator). Install went fine and Maxthon works fine. However when I checked installation folder it was installed into C:\Program Files (x86)\Maxthon5\5.1.2.200\5.1.2.1000. (even though on installation window I only provided path C:\Program Files (x86)\Maxthon5) 5. When trying to upgrade this installation to 5.1.2.X branch again, it again runs to 64% and stops without doing any changes. I think it started when I tried to install one of the first versions from 5.1.2.X branch. I think it was 5.1.2.100.beta. Please help me fix this issue. Maybe something stuck in system registery ? Link to comment Share on other sites More sharing options...
MrChat Posted September 29, 2017 Author Report Share Posted September 29, 2017 With 5.1.2.3000 I was able to install, kinda. Running 5.1.2.3000 installer was showing progress till 92% and then installer disappeared. No upgrade happened to my already installed 5.1.1.1000. I uninstalled 5.1.1.1000. Executed 5.1.2.3000 installer, same effect. Progress till 92% and disappear - Maxthon5 folder was created only in user/AppData/Roaming, nothing in Program Files (x86). Then I executed 5.1.2.3000 installer as administrator and it got fully installed. Link to comment Share on other sites More sharing options...
