some problems
Posted
Hello, i am newbie.
i decided that using maxthon5 anymore. (i learned we call it mx5 okay ^^) i have some problems about mx5.
i used chrome browser in 5 years. so i lacking of my requiments.
1 - i dont find clear cache only ONE PAGE. (like chrome) (upload images) (i dont want to press F12 and clear storage section.. it is so far)
2 - Lastpass extension doesnt work. it works but dont auto fill password or logins action to textbox. is it about mx5 extensions?
3 - there is a RSS feader in mx5. good but i see it only on sidebar. is there anyway carry to extension bar?
4 - i found some extensions. but i think they are working in old mx version. so mx5 didnt work it. maybe it will be developed?
5 - i install mx5 in android phone. but i see that there isnt browser's history. is there any way sync them (android + computer) ?
6 - i found some article about pack extensions. (thanks to AS) he give tips to wrote some extension with MXPacker. so i prepare an extension about translator. so what it doesnt work. i think it is about mx5. is there a tips setting up an extension on mx5?
Thnx. have a nice days ^^
Posted
Something that i've been asking about for years. Seems they don't think it's required...maybe someday.
That should be an easy one to change to make it available on the toolbar. Will look into it.
Which ones?
I don't think history is something that gets synced. Only favourites i believe.
Do you get any errors in the devtools console?
If you can post the code/files, someone might be able to have a look at it.
