-ody- Posted July 9, 2017 Report Share Posted July 9, 2017 export as a text file works, but export as html does not share : copy button does not work if I manually copy the link to open the note, https://www.uu.me/s/whxni60o, I get a dialogbox for share but text of icons is in chinese Tip Give Link to comment Share on other sites More sharing options...
7twenty Posted July 9, 2017 Report Share Posted July 9, 2017 You're right. There's no link in the txt or html export options. Clearly an issue there. The copy button does work for me. You get a "link copied" overlay on the URL. Clicking the facebook/linkedin/twitter buttons opens a new tab which i'm guessing directly adds the link to a post/tweet etc. Tip Give Link to comment Share on other sites More sharing options...
karajan Posted July 9, 2017 Report Share Posted July 9, 2017 i took a snapshot of the whole page and export as html and i got the snapshot as in maxnote and with the original clickable link at the bottom of the page the same with two random webpages i saved as a bookmark and then export as txt and i got the link ( not clickable anyway it's plain text ) no html naturally share button i don't give a damn using portable 5.1.0.1900 Tip Give Link to comment Share on other sites More sharing options...
-ody- Posted July 10, 2017 Author Report Share Posted July 10, 2017 11 hours ago, karajan said: i took a snapshot of the whole page and export as html and i got the snapshot as in maxnote and with the original clickable link at the bottom of the page the same with two random webpages i saved as a bookmark and then export as txt and i got the link ( not clickable anyway it's plain text ) no html naturally share button i don't give a damn using portable 5.1.0.1900 not sure about snapshot, I didnt try, what I used was webcontent, but it shoudn't make any difference during with export process about share : I didn't try to share on social media, just the "copy" button to send the webcontent to my husband, and it did not work here, and selecting the link did not work either. only way is to manually copy the link, which is tedious. I will try a clean install (hoping to no lose my QA this time) Tip Give Link to comment Share on other sites More sharing options...
PHYR Posted July 10, 2017 Report Share Posted July 10, 2017 15 hours ago, -ody- said: not sure about snapshot, I didnt try, what I used was webcontent, but it shoudn't make any difference during with export process about share : I didn't try to share on social media, just the "copy" button to send the webcontent to my husband, and it did not work here, and selecting the link did not work either. only way is to manually copy the link, which is tedious. I will try a clean install (hoping to no lose my QA this time) I wonder if it is not the same issue as win 10 build 16232 having issues with copy but fixed in build 16237. " We’re investigating your reports that the Copy Link option displayed in Microsoft Edge when you right-click a hyperlink isn’t working in recent builds. Tip Give Link to comment Share on other sites More sharing options...
