Sergey_K Posted June 20, 2017 Report Share Posted June 20, 2017 See attached screenshot. Tip Give Link to comment Share on other sites More sharing options...
karajan Posted June 20, 2017 Report Share Posted June 20, 2017 works for me with the last official or the last beta (portable) Tip Give Link to comment Share on other sites More sharing options...
Sergey_K Posted June 20, 2017 Author Report Share Posted June 20, 2017 How does this work? Where is the screenshot saved? (in what folder is it maxnote?) Tip Give Link to comment Share on other sites More sharing options...
Artee Posted June 20, 2017 Report Share Posted June 20, 2017 After clicking "Add to Maxnote" the usual save window appears And you select where you wanna save it Tip Give Link to comment Share on other sites More sharing options...
7twenty Posted June 20, 2017 Report Share Posted June 20, 2017 It will save to the folder you pick from the dialog above. Once saved it should show a link at the top right of screen which will take you directly to the folder. Although I think there is a bug. When saving to "All Folders" you can't find the saved item in the list when checking maxnote. But you can search for it and it will be found. Adding to any sub-folder works correctly as it is shown in the listing of the folder. Tip Give Link to comment Share on other sites More sharing options...
Artee Posted June 20, 2017 Report Share Posted June 20, 2017 2 hours ago, 7twenty said: It will save to the folder you pick from the dialog above. Once saved it should show a link at the top right of screen which will take you directly to the folder. Although I think there is a bug. When saving to "All Folders" you can't find the saved item in the list when checking maxnote. But you can search for it and it will be found. Adding to any sub-folder works correctly as it is shown in the listing of the folder. Hmmm... it shows up under "All folders" fine on my end with no searching (5.1.0.1400). Tip Give Link to comment Share on other sites More sharing options...
7twenty Posted June 21, 2017 Report Share Posted June 21, 2017 5 hours ago, Artee said: Hmmm... it shows up under "All folders" fine on my end Hmmm, will have to have another look then. Tip Give Link to comment Share on other sites More sharing options...
Sergey_K Posted June 21, 2017 Author Report Share Posted June 21, 2017 8 hours ago, 7twenty said: It will save to the folder you pick from the dialog above. I do not even have this dialog box. I described in the screenshot: after selecting the desired region on the page - you click the icon with the "bee" and nothing happens (only the copy is saved on the clipboard). Tip Give Link to comment Share on other sites More sharing options...
PHYR Posted June 21, 2017 Report Share Posted June 21, 2017 56 minutes ago, 7twenty said: Hmmm, will have to have another look then. I've had this happen before but for adding a favorite, but with this version I didn't have an issue adding the snap. Tip Give Link to comment Share on other sites More sharing options...
7twenty Posted June 21, 2017 Report Share Posted June 21, 2017 3 minutes ago, Sergey_K said: I do not even have this dialog box. Do you see it when you click the bee icon in the address bar? If not, reinstall should fix what ever the issue is. You don't mention what version you're using. If you have to reinstall, get the most recent version from here:http://forum.maxthon.com/index.php?/release-notes5/ Tip Give Link to comment Share on other sites More sharing options...
PHYR Posted June 21, 2017 Report Share Posted June 21, 2017 9 minutes ago, Sergey_K said: I do not even have this dialog box. I described in the screenshot: after selecting the desired region on the page - you click the icon with the "bee" and nothing happens (only the copy is saved on the clipboard). Clicking the copy button should open Add to Maxnote at upper right. BTW, there is no save button when using the bee to ad to Maxnote, I used regular snap for the image.... Tip Give Link to comment Share on other sites More sharing options...
Sergey_K Posted June 21, 2017 Author Report Share Posted June 21, 2017 I have the latest version of V 5.1.0.1400 Released 06/13/2017 Well, now I'll try to reinstall anew. Tip Give Link to comment Share on other sites More sharing options...
Sergey_K Posted June 21, 2017 Author Report Share Posted June 21, 2017 Ah-a-a-a-a-a !!! I understood the reason! I have installed and applied the theme "Classic" in the Personalization settings of Windows 7. If you choose and apply the theme "Aero", then everything works! Probably the developers did not consider that someone will use the classic theme Win7 - for me, for example, it is more like it, this should not suffer from the functionality of the browser! Tip Give Link to comment Share on other sites More sharing options...
Chantao Posted June 21, 2017 Report Share Posted June 21, 2017 You have to snap and click twice Tip Give Link to comment Share on other sites More sharing options...
Sergey_K Posted June 21, 2017 Author Report Share Posted June 21, 2017 Here, I recorded the video: It is interesting that the dialog for saving the screenshot appears only after clicking on the title of the active tab Tip Give Link to comment Share on other sites More sharing options...
