Perplexer Posted May 4, 2017 Report Share Posted May 4, 2017 This is an old problem with Nitroflare and Maxthon and I didn't find any post about it yet. Basically links to Nitroflare.com can not be successfully opened, at least not on my PC. For example http://nitroflare.com/view/788304F7322748C It works normally in Firefox and Chrome though. Can anyone confirm ? I'm currently using MX5.0.4.500 beta but the issue also appears with MX4.9. Tip Give Link to comment Share on other sites More sharing options...
No.1MaxthonFan Posted May 5, 2017 Report Share Posted May 5, 2017 Switching to retro mode it works fine. Windows 10 64-bit build 10525/Windows 10 Mobile build 10512 Tip Give Link to comment Share on other sites More sharing options...
Perplexer Posted May 5, 2017 Author Report Share Posted May 5, 2017 Not for me. Are you using a modified User Agent ? Tip Give Link to comment Share on other sites More sharing options...
No.1MaxthonFan Posted May 5, 2017 Report Share Posted May 5, 2017 5 hours ago, Perplexer said: Not for me. Are you using a modified User Agent ? Nope, just using the default UA. Windows 10 64-bit build 10525/Windows 10 Mobile build 10512 Tip Give Link to comment Share on other sites More sharing options...
7twenty Posted May 7, 2017 Report Share Posted May 7, 2017 Works fine in Retro (with standard rendering enabled). And doesn't like the Maxthon string in the UA. Remove that and it works fine. Given some of the issues lately, i'd be tempted to recommend everyone just use the Chrome string in the UA settings. Tip Give Link to comment Share on other sites More sharing options...
BugSir006 Posted May 8, 2017 Report Share Posted May 8, 2017 Seems doesn't work on my side in both modes. Will forward this site to developers, the solution could be to push a new UA for this site. Tip Give Link to comment Share on other sites More sharing options...
