Give a tip
Auto import issue
Hello,everytime when I open Maxthon it automatically imports bookmarks and other seetings from IE.It adds bookmarks with a number eachtime you open maxthon.To see,just click on start icon (bookmark icon),you will see files imported from IE.And also it adds homepage from IE too.
Example:
With clean install (guest login)
Tip   Give
35 minutes ago, PHYR said:
What happens if you don't change Maxthon.dll hex file?
Otherwise, try a clean install.
Tried everthing. (note that I use a guest account when open Maxthon)
Here is the result with a clean install:
Tip   Give
Even with a guest account, IE favorites were only imported once when I used the import tool. Multiple reboots did not re-import IE favs. No idea other then trying a clean install(Did you delete all info when asked?). You might check that there is no Maxthon folder in your appdata folder after uninstalling.
Tip   Give
The file that tells it that an import has been done isn't being saved properly, or being reset for some reason.
Go to \UserData\Temp\DataImporter and open the config.ini file. Post the contents here.
Also check that the file isn't read-only for some strange reason.
Tip   Give
Yes, appdata folder were also deleted after a clean install.
Thank you. I've checked and there was missing lines in config file.After adding the following lines, the problem solved:
ImportStateForFavorites=1
Tip   Give
