EddyFicio Posted January 16, 2017 Report Share Posted January 16, 2017 Tip Give Link to comment Share on other sites More sharing options...
karajan Posted January 16, 2017 Report Share Posted January 16, 2017 have you tried the usual things: clear data; disable all exensions; try incognito mode; check parental permissions in your AV and the rules of the firewall; uninstal reinstal; scan for viruses what are the last modifications that you've done before this error appears? it was an issue with chrome not simple to fix Tip Give Link to comment Share on other sites More sharing options...
