DARKSTORM 30 Posted December 5, 2016 Report Share Posted December 5, 2016 Upload/Download Speed Indicator is not working again. This problem also appeared from the past Mx version but I can't find the recent topic There was an error notification shown then the indicator does not work anymore. Probably a broken file Tried "Fix It" from MxUninstaller - didn't work Clean Uninstall then reboot then Install - Doesn't work also Tip Give Link to post Share on other sites
7twenty 1,246 Posted December 5, 2016 Report Share Posted December 5, 2016 is it detecting a network connection? Or there's nothing to select? Tip Give Link to post Share on other sites
BugSir006 1,247 Posted December 7, 2016 Report Share Posted December 7, 2016 Hi DARKSTROM, could you tell us your version number? And is it 1, when you select upload/download speed indicator there's nothing happened and they even do not show on status bar? 2, or, the numbers always show zero? Tip Give Link to post Share on other sites
joemax 100 Posted December 7, 2016 Report Share Posted December 7, 2016 Check that you have the right controller selected... Tip Give Link to post Share on other sites
RoofChyk 10 Posted December 7, 2016 Report Share Posted December 7, 2016 The indicator and I have also never works. Any version. Laptop connected to the internet through Wi Fi. Just zeros are displayed. and there is no menu to select the controller. ver. 5.0.2.200/beta, Windows 10 Home, x64 Tip Give Link to post Share on other sites
DARKSTORM 30 Posted December 8, 2016 Author Report Share Posted December 8, 2016 Sorry for the late reply. Mine is same with RoofChyk but my version is 5.0.1.3000 On 12/5/2016 at 0:52 PM, 7twenty said: is it detecting a network connection? Or there's nothing to select? There's nothing to select Tip Give Link to post Share on other sites
7twenty 1,246 Posted December 9, 2016 Report Share Posted December 9, 2016 8 hours ago, DARKSTORM said: There's nothing to select Need to figure out why that is the case. Vaguely recall there being a fix/workaround to get it working ages ago. But no idea off the top of my head. Tip Give Link to post Share on other sites
DARKSTORM 30 Posted December 9, 2016 Author Report Share Posted December 9, 2016 2 hours ago, 7twenty said: Need to figure out why that is the case. Vaguely recall there being a fix/workaround to get it working ages ago. But no idea off the top of my head. The topic is probably deleted. I tried searching before posting but no hope Tip Give Link to post Share on other sites
PHYR 472 Posted December 9, 2016 Report Share Posted December 9, 2016 17 minutes ago, DARKSTORM said: The topic is probably deleted. I tried searching before posting but no hope It was in the old forum. The devs have to look into it, there is no fix. Tip Give Link to post Share on other sites
7twenty 1,246 Posted December 9, 2016 Report Share Posted December 9, 2016 12 hours ago, PHYR said: The devs have to look into it, there is no fix. Odd. The fact that it clearly does work for other users, means there's something going on with that system. Either it can't read something from where ever that data comes from, or there is something different that MX isn't aware of/able to deal with. @DARKSTORM What is your ethernet/wireless device? Look in Device Manager > network adapters And can you try using ethernet to see if it's related only to WiFi or all your network devices? Tip Give Link to post Share on other sites
DARKSTORM 30 Posted December 10, 2016 Author Report Share Posted December 10, 2016 12 hours ago, 7twenty said: Odd. The fact that it clearly does work for other users, means there's something going on with that system. Either it can't read something from where ever that data comes from, or there is something different that MX isn't aware of/able to deal with. @DARKSTORM What is your ethernet/wireless device? Look in Device Manager > network adapters And can you try using ethernet to see if it's related only to WiFi or all your network devices? Network Adapters: Realtek PCIe GBE Family Controller, TAP-Win32 V9 This Adapters are from a Windows 10 PC, Also has the indicator not working. The other one that has its indicator not working had an error before its indicator stopped working. Found my Old Post. Tip Give Link to post Share on other sites
BugSir006 1,247 Posted December 12, 2016 Report Share Posted December 12, 2016 Hi DARKSTORM, can you recall the steps that mentioned here? Tip Give Link to post Share on other sites
DARKSTORM 30 Posted December 12, 2016 Author Report Share Posted December 12, 2016 29 minutes ago, BugSir006 said: Hi DARKSTORM, can you recall the steps that mentioned here? Unfortunately, No Tip Give Link to post Share on other sites
7twenty 1,246 Posted December 13, 2016 Report Share Posted December 13, 2016 On 12/12/2016 at 8:36 PM, DARKSTORM said: Unfortunately, No There was a hidden link in a post in that thread. Details below. Quote Info display problem in Status Bar like upload speed etc, (not including CPU usage sorry). We confirm that the problem is caused by the empty content in the counter of HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Perflib\009 or 0804. For that the previous version before 3.3.7.800 uses another read way, they are not influenced by this key value. However, it may cause the icon lost in Side Bar. So, from 3.3.7.1000, we restore the read way of Maxthon 2 that reads the counter from the registry. Solution: We can solve this problem by regenerate the counter: Open a Command Prompt window(Win+R and enter "CMD" then click "Enter"). Input " cd \windows\system32 " the click "Enter" Input "lodctr /r" and click "Enter" Then wait for one moment, until it appears "Successfully rebuilt performance counter setting from system backup store". Restart the browser to see whether it works. Hopefully the same fix still works. Tip Give Link to post Share on other sites
DARKSTORM 30 Posted December 14, 2016 Author Report Share Posted December 14, 2016 15 hours ago, 7twenty said: There was a hidden link in a post in that thread. Details below. Hopefully the same fix still works. Need to Run as Administrator Fix Works!!! Thumbs Up Tip Give Link to post Share on other sites
RoofChyk 10 Posted December 17, 2016 Report Share Posted December 17, 2016 On 13.12.2016 at 0:16 AM, 7twenty said: Hopefully the same fix still works. it really works. Thank you from the heart Tip Give Link to post Share on other sites
Sebast. 1 Posted December 17, 2016 Report Share Posted December 17, 2016 I searched but I cant find this addon. Where can I get it ? Im with MX5.0.2.900. Thanks Tip Give Link to post Share on other sites
7twenty 1,246 Posted December 17, 2016 Report Share Posted December 17, 2016 5 hours ago, Sebast. said: I searched but I cant find this addon. Where can I get it ? Menu > Settings > Functions & addons > Utility > CPU usage Make sure it's enabled. Tip Give Link to post Share on other sites
BugSir006 1,247 Posted December 19, 2016 Report Share Posted December 19, 2016 Really thank U! 7twenty! Tip Give Link to post Share on other sites
Sebast. 1 Posted December 26, 2016 Report Share Posted December 26, 2016 Yes its enable but I dont have the bar at the buttom of the windows... Tip Give Link to post Share on other sites
PHYR 472 Posted December 27, 2016 Report Share Posted December 27, 2016 6 hours ago, Sebast. said: Yes its enable but I dont have the bar at the buttom of the windows... You also have to enable it to show from settings > view > status bar. Tip Give Link to post Share on other sites
Sebast. 1 Posted December 27, 2016 Report Share Posted December 27, 2016 Thanks you very much for all guys! Merry christmas and happy new year! Tip Give Link to post Share on other sites
