abkoshi Posted September 4, 2016 Report Share Posted September 4, 2016 Looks like the developers forgot to include certain modules with this release of Mx5 beta2. - Mouse Gestures - Shortcuts (Ctrl-F, Ctrl-S etc) - Translation - Snap - Night Mode Translation & Night Mode was missing in Beta 1 also. Beta2 was released after a long wait. But the release is disappointing. To find a certain text in the page, now I have to use the mouse. Quick Access is like dumping a folder of shortcuts into the page without proper title or description. There is no advantage in shifting to Mx5 from Mx4. Tip Give Link to comment Share on other sites More sharing options...
QIK5L Posted September 4, 2016 Report Share Posted September 4, 2016 They are all there in latest beta, have you done a clean install of MX5? - Shortcuts (Ctrl-F, Ctrl-S etc) - Translation- Snap- Night Mode Have you enabled them under settings / functions & add-ons? Tip Give Link to comment Share on other sites More sharing options...
dagoz Posted September 4, 2016 Report Share Posted September 4, 2016 Missing most of the good features of Maxthon 4. I fear that you may have wasted your time and resources in making Maxthon 5. Passkeeper and UUMail are not needed and Infobox is unfathomable in my opinion. Maxthon 4 (4.4.1.800) was working fine and the updates just make Maxthon 5 too complicated, why fix something that is not broken? Tip Give Link to comment Share on other sites More sharing options...
abkoshi Posted September 5, 2016 Author Report Share Posted September 5, 2016 Qik5l, I use portable Maxthon. I do not prefer to install. In fact, I carry the same browser in most places in a USB drive. If you go to Settings-> Gestures & Shortcuts, I find nothing there and there is no provision to create my own. Translation & snap is also a required feature which I cannot locate now and how do I enable them in Addons? Please help. Tip Give Link to comment Share on other sites More sharing options...
Kilmatar Posted September 5, 2016 Report Share Posted September 5, 2016 I'm using portable version and 5.0.1.1200 works fine. Settings - Functions&Addons and check enabled functions Tip Give Link to comment Share on other sites More sharing options...
BugSir006 Posted September 5, 2016 Report Share Posted September 5, 2016 Hi abkoshi, could you provide a screenshot for us? I'm also using a protable 1200 version, please make sure these functions are enabled in setting-addons. Tip Give Link to comment Share on other sites More sharing options...
PHYR Posted September 5, 2016 Report Share Posted September 5, 2016 Management links open settings: Tip Give Link to comment Share on other sites More sharing options...
abkoshi Posted September 6, 2016 Author Report Share Posted September 6, 2016 This is how I get. Is there something wrong with my installation? functions & gestures Tip Give Link to comment Share on other sites More sharing options...
BugSir006 Posted September 6, 2016 Report Share Posted September 6, 2016 30 minutes ago, abkoshi said: This is how I get. Is there something wrong with my installation? Try here please Tip Give Link to comment Share on other sites More sharing options...
abkoshi Posted September 6, 2016 Author Report Share Posted September 6, 2016 No options in Utility or Browsing Tip Give Link to comment Share on other sites More sharing options...
QIK5L Posted September 6, 2016 Report Share Posted September 6, 2016 have you dowloaded a new copy of portable and tried that? Tip Give Link to comment Share on other sites More sharing options...
abkoshi Posted September 7, 2016 Author Report Share Posted September 7, 2016 yes i have downloaded a new version. Deleted all old ones and it is working fine now. All functions, add-ons, gestures all ok. Thank you very much for your help. Tip Give Link to comment Share on other sites More sharing options...
