magg Posted July 26, 2016 Report Posted July 26, 2016 When you try to add websites to QA by "Plus" button, site thumbnails/ icons are broken. Few examples http://olx.pl/ http://www.90minut.pl
Mhzayer Posted July 26, 2016 Report Posted July 26, 2016 Salam Magg I had the same issue I deleted those old imported and then added them back I had the icons back
magg Posted July 26, 2016 Author Report Posted July 26, 2016 36 minutes ago, Mhzayer said: Salam Magg I had the same issue I deleted those old imported and then added them back I had the icons back Thanks for checking. Those websites aren't imported. I added them anew by "Plus" button.
Mhzayer Posted July 26, 2016 Report Posted July 26, 2016 1 minute ago, magg said: Thanks for checking. Those websites aren't imported. I added them anew by "Plus" button. They were synced I guess I had only one added to that page and it was added to the new MX5 automatically So it was synced It had the same icon as those you added but when I added it through the plus icon It was OK
magg Posted July 26, 2016 Author Report Posted July 26, 2016 4 minutes ago, Mhzayer said: They were synced I guess I had only one added to that page and it was added to the new MX5 automatically So it was synced It had the same icon as those you added but when I added it through the plus icon It was OK Thanks again. Could you check on your device those sites http://olx.pl/ http://olx.pl/ http://www.90minut.pl ,please? Tried on my 2 different android devices - still no go.
BugMiss006 Posted July 27, 2016 Report Posted July 27, 2016 Hello, magg. Thanks your feedback and others confirm firstly. I can't test it, because I don't have Android Phone. I already transferred this issue to test team. If it's confirmed, I will tell you as soon as possible.
Mhzayer Posted July 27, 2016 Report Posted July 27, 2016 19 hours ago, magg said: Thanks again. Could you check on your device those sites http://olx.pl/ http://olx.pl/ http://www.90minut.pl ,please? Tried on my 2 different android devices - still no go. Salam Magg I first added olx.pl Then I added olx.pl/
magg Posted July 27, 2016 Author Report Posted July 27, 2016 1 minute ago, Mhzayer said: Salam Magg I first added olx.pl Then I added olx.pl/ Thank you very much. But did you try to add them by using the "+" button on Quick Access page?
Mhzayer Posted July 27, 2016 Report Posted July 27, 2016 14 minutes ago, magg said: Thank you very much. But did you try to add them by using the "+" button on Quick Access page? That's exactly what I did For the 90minut link tried every thing but to no avail
magg Posted August 1, 2016 Author Report Posted August 1, 2016 Still the same problem in new beta 5.1.1000 ... The only way is adding those problematic websites by "Add to Launcher" >> "Add to QA". So "+" button is useless so far.
