adli89 Posted July 13, 2016 Report Share Posted July 13, 2016 On 1 of my computers, all my MagicFills are transferred to Maxthon 5's Passkeeper. However on my other computer, the Passkeeper is empty. Scared, I uninstalled Maxthon 5 and installed back Maxthon 4 to check. All my MagicFills came back, fortunately. I tried Maxthon 5 again and the same thing happens, Passkeeper is empty. Is there any way to force sync? Tip Give Link to comment Share on other sites More sharing options...
adli89 Posted July 16, 2016 Author Report Share Posted July 16, 2016 Nobody have the same problem? Looks like very isolated case then.. I reinstalled countless times and still cannot get my MagicFills to Passkeeper. Tip Give Link to comment Share on other sites More sharing options...
No.1MaxthonFan Posted July 16, 2016 Report Share Posted July 16, 2016 14 minutes ago, adli89 said: Nobody have the same problem? Looks like very isolated case then.. I reinstalled countless times and still cannot get my MagicFills to Passkeeper. Odd, all 262 entries were transferred over. Windows 10 64-bit build 10525/Windows 10 Mobile build 10512 Tip Give Link to comment Share on other sites More sharing options...
joemax Posted July 16, 2016 Report Share Posted July 16, 2016 I think you should try to force sync of magic fill in M4 before installing M5. Tip Give Link to comment Share on other sites More sharing options...
abkoshi Posted July 18, 2016 Report Share Posted July 18, 2016 I am facing the same problem. All my saved passwords are not available in MX5. I synched my settings before installing mx5 Tip Give Link to comment Share on other sites More sharing options...
abkoshi Posted July 18, 2016 Report Share Posted July 18, 2016 Yes second time I got all. Perhaps it would take sometime to transfer. Tip Give Link to comment Share on other sites More sharing options...
No.1MaxthonFan Posted July 18, 2016 Report Share Posted July 18, 2016 1 minute ago, abkoshi said: Yes second time I got all. Perhaps it would take sometime to transfer. Yes, it unfortunately is not instantaneous and does take some time to finish. Windows 10 64-bit build 10525/Windows 10 Mobile build 10512 Tip Give Link to comment Share on other sites More sharing options...
adli89 Posted July 18, 2016 Author Report Share Posted July 18, 2016 9 hours ago, No.1MaxthonFan said: Yes, it unfortunately is not instantaneous and does take some time to finish. Did you guys uninstall MX4 first before installing MX5? If you do, did you also clear all user data? Tip Give Link to comment Share on other sites More sharing options...
-ody- Posted July 18, 2016 Report Share Posted July 18, 2016 4 minutes ago, adli89 said: Did you guys uninstall MX4 first before installing MX5? If you do, did you also clear all user data? backup your data before you install Mx5, remember Mx5 is an alpha. Tip Give Link to comment Share on other sites More sharing options...
No.1MaxthonFan Posted July 18, 2016 Report Share Posted July 18, 2016 9 minutes ago, adli89 said: Did you guys uninstall MX4 first before installing MX5? If you do, did you also clear all user data? I uninstalled Maxthon 4 before installing Maxthon 5 and yes, I did delete all user data. But all of my Magic Fill data came over becaused it was sync'd to the cloud. Windows 10 64-bit build 10525/Windows 10 Mobile build 10512 Tip Give Link to comment Share on other sites More sharing options...
MIKEB2ru Posted July 19, 2016 Report Share Posted July 19, 2016 In my case, everything is synchronized. MagicFill data were synced to the folder "Autosaved Passwords" in Passkeeper. Unfortunately, I could not move them in my newly created Passkeeper account. Perhaps this feature is not implemented yet. We await developments. Tip Give Link to comment Share on other sites More sharing options...
abkoshi Posted July 19, 2016 Report Share Posted July 19, 2016 I was using portable Maxthon Mx4. I have got all my Magic Fill now. Thank You. Tip Give Link to comment Share on other sites More sharing options...
BugMiss006 Posted July 20, 2016 Report Share Posted July 20, 2016 I also tried many times, but can't duplicate. It looks like a very isolated case. After discuss, we decided to add some manual sync button in later versions. Hope it can solve this issue. Thanks adli89's feedback and others confirm. Tip Give Link to comment Share on other sites More sharing options...
-ody- Posted July 20, 2016 Report Share Posted July 20, 2016 3 hours ago, BugMiss006 said: After discussion, we decided to add some manual sync button in later versions. Hope it can solve this issue. a button to force sync ? or a button to enable/disable sync ? and synchronisation lacks of options : we should be able to choose what we want to synchronise (favorites, magic fill, notes;;;) and which version we want to synchronise : "online to local" or "local to online" Tip Give Link to comment Share on other sites More sharing options...
BugMiss006 Posted July 21, 2016 Report Share Posted July 21, 2016 22 hours ago, -ody- said: a button to force sync ? or a button to enable/disable sync ? and synchronisation lacks of options : we should be able to choose what we want to synchronise (favorites, magic fill, notes;;;) and which version we want to synchronise : "online to local" or "local to online" a button to force sync. I will send those suggestions for sync function to product managers. Keep in touch, dear. Tip Give Link to comment Share on other sites More sharing options...
-ody- Posted July 21, 2016 Report Share Posted July 21, 2016 1 hour ago, BugMiss006 said: a button to force sync. I will send those suggestions for sync function to product managers. Keep in touch, dear. sync function : sync is forced, it happens every time you open the browser, you can't choose what you sync, sometimes I don't even have the time to make a try, if I create a new folder in notes, as soon as created it's synced... sometimes you realize old version was better, you think you will retrieve it in your online notes, too late.. new one is synced already ! I don't like this at all ! Tip Give Link to comment Share on other sites More sharing options...
-ody- Posted July 23, 2016 Report Share Posted July 23, 2016 http://fav.maxthon.com/api/fav no matter how many time I have tried to force the sync, favs online are not updated : the online version is a several days old version. Tip Give Link to comment Share on other sites More sharing options...
No.1MaxthonFan Posted July 23, 2016 Report Share Posted July 23, 2016 2 hours ago, -ody- said: http://fav.maxthon.com/api/fav no matter how many time I have tried to force the sync, favs online are not updated : the online version is a several days old version. Confirmed. Online favorites are old. Windows 10 64-bit build 10525/Windows 10 Mobile build 10512 Tip Give Link to comment Share on other sites More sharing options...
Yuizen Posted July 23, 2016 Report Share Posted July 23, 2016 I uninstalled MX4 removed user data and everything. Then install MX5, the only ones got sync are my bookmarks, passkeeper is empty. Both Accounts and Auto saved password is empty. Is there a fix on this? All my passwords are already sync into the cloud already since I have been using Maxthon for a long time. Also I tried to install MX4 again and password are sync into it. Then install MX5 again still passkeeper is empty. Tip Give Link to comment Share on other sites More sharing options...
-ody- Posted July 23, 2016 Report Share Posted July 23, 2016 45 minutes ago, Yuizen said: I uninstalled MX4 removed user data and everything. Then install MX5, the only ones got sync are my bookmarks, passkeeper is empty. Both Accounts and Auto saved password is empty. Is there a fix on this? All my passwords are already sync into the cloud already since I have been using Maxthon for a long time. Also I tried to install MX4 again and password are sync into it. Then install MX5 again still passkeeper is empty. (could it be an issue with the server ?) my favs do no longer sync either, although I had no issue last week (but last week I had Mx 5 2600.. ) notes are not synced either.. but all of this works in Mx 4, and worked in 2600 Tip Give Link to comment Share on other sites More sharing options...
Yuizen Posted July 23, 2016 Report Share Posted July 23, 2016 25 minutes ago, -ody- said: there could be an issue with the server since my favs do no longer sync either, although I had no issue last week (but last week I had Mx 5 2600.. ), and my notes are not synced either.. but they do sync in Mx 4 I'll wait for the devs to fix it then, it's still Alpha so can't complain really, just reporting. Thanks Tip Give Link to comment Share on other sites More sharing options...
adli89 Posted July 24, 2016 Author Report Share Posted July 24, 2016 Thanks for the response guys! I still cannot sync my MagicFills back to Passkeeper. Fully understand that this is Alpha, I'm used to alpha stuffs as I'm a software developer myself. Using Windows 10 Insider Previews also makes me get used to bugs Looking forward to the force sync feature coming in the future Tip Give Link to comment Share on other sites More sharing options...
adli89 Posted July 24, 2016 Author Report Share Posted July 24, 2016 On 7/23/2016 at 6:58 PM, Yuizen said: I uninstalled MX4 removed user data and everything. Then install MX5, the only ones got sync are my bookmarks, passkeeper is empty. Both Accounts and Auto saved password is empty. Is there a fix on this? All my passwords are already sync into the cloud already since I have been using Maxthon for a long time. Also I tried to install MX4 again and password are sync into it. Then install MX5 again still passkeeper is empty. Same issue happened to me, and I created a thread here Force sync feature is coming in the future, so that might help in resolving our issue Tip Give Link to comment Share on other sites More sharing options...
PablooS Posted July 24, 2016 Report Share Posted July 24, 2016 I had this problem when i had Magic Fill Settings > Manual. I had 0 MF. When I set option to Auto, I have all my saved passwords in bookmark "Autosaved Passwords". Tip Give Link to comment Share on other sites More sharing options...
-ody- Posted July 27, 2016 Report Share Posted July 27, 2016 sync (favs and notes) still does not work in 2800 : I've added a note to my phone (skynote), sync works with 4.9, the note is there in 4.9, but in Mx5 my notes are not updated online favs http://fav.maxthon.com/api/fav are not updated (they are 3 weeks old now) Tip Give Link to comment Share on other sites More sharing options...
BugMiss006 Posted July 27, 2016 Report Share Posted July 27, 2016 On 2016/7/21 at 1:24 PM, -ody- said: sync function : sync is forced, it happens every time you open the browser, you can't choose what you sync, sometimes I don't even have the time to make a try, if I create a new folder in notes, as soon as created it's synced... sometimes you realize old version was better, you think you will retrieve it in your online notes, too late.. new one is synced already ! I don't like this at all ! Got it, dear. We will consider. Tip Give Link to comment Share on other sites More sharing options...
