iKerry Posted May 22, 2016 Report Share Posted May 22, 2016 https://www.netflix.com/browse does not display correctly using Maxthon v4.4.8.2000. With Firefox, Google, or Slimjet when one mouses over a movie it expands the image and displays text that describes the movie, also it displays an add to "+ MY LIST" button. Anyone know how to make a shortcut (such as Netflix) that's located on my desktop to open a browser other than my default Maxthon? Thanks, Kerry Windows 10Maxthon v4.4.8.2000 Tip Give Link to comment Share on other sites More sharing options...
7twenty Posted May 23, 2016 Report Share Posted May 23, 2016 Not 100%, but doing the below should fix that issue: Use retro mode, and make sure "standard rendering in Retro Mode" is enabled in Settings > Web content If that doesn't work, then as far as making a shortcut, try this: On the desktop, right-click > New > Shortcut In the location box enter the path to the browser you want to use & the website eg: C:\program files (x86)\Firefox\firefox.exe www.netflix.com Next Change the name to whatever you want Finish Tip Give Link to comment Share on other sites More sharing options...
iKerry Posted May 24, 2016 Author Report Share Posted May 24, 2016 On 23/5/2016 at 2:08 AM, 7twenty said: Not 100%, but doing the below should fix that issue: Use retro mode, and make sure "standard rendering in Retro Mode" is enabled in Settings > Web content That did it 100%. Thanks muchly 7twenty. Kerry Tip Give Link to comment Share on other sites More sharing options...
