4.4.8.2000 Portable Installation crashs on clear browsing data exit function
Slec
Posted
Hi All,
When the user decides to use the command Ctrl+Shift+Del to clear the browsing data on this version, 4.4.8.2000 Portable Installation, it crashs when pushed the button "Clear now", conflicting some modules old version modules of 4.4.8.1000 revision.
Hope you can fix it for new revision.
Thanks in advance, BR.
Posted
7 minutes ago, Slec said:
Hi All,
Yes, it's well know bug...
Uncheck/ untick "Auto clear on exit" option (as a workaround)
And I don't think that will be ever fixed.
4.4.8.2000 is the last build from old branch (unfortunately).
Now - most current/ updated and with full support are 4.9's branch builds.
Posted
14 hours ago, Slec said:
Hi All,
Hi, guys~ good news~ This bug is already fixed in V4.9. you can ungrade it and have a try. The installation package of newest version link: http://forum.maxthon.com/index.php?/topic/19377-changelog-for-maxthon-test-version-492500/
