Jessica Lily Posted January 2, 2016 Report Share Posted January 2, 2016 This is the error that displays when i try to visit few websites............ PLEASE HELP ME FASTTTTTT ASAP!!!! Invalid certificate This site's certificate has expired or has been issued for a different website's address. This problem may indicate an attempt to intercept the data between you and remote server. Please check whether the URL in the address bar is correct. Error code 113 (net::ERR_SSL_VERSION_OR_CIPHER_MISMATCH) This problem is showing from maybe 3or more months........ I NEED HELP!!!!!!!! Im UNABLE TO OPEN THE SITES I WANT My system is Windows XP ANYONE SOMEONE HELPPPPPPPPPPPPPPPPPPPPPPPPPPP Tip Give Link to comment Share on other sites More sharing options...
SnowLeopard Posted January 2, 2016 Report Share Posted January 2, 2016 2 hours ago, Jessica Lily said: This is the error that displays when i try to visit few websites............ PLEASE HELP ME FASTTTTTT ASAP!!!! Invalid certificate This site's certificate has expired or has been issued for a different website's address. This problem may indicate an attempt to intercept the data between you and remote server. Please check whether the URL in the address bar is correct. Error code 113 (net::ERR_SSL_VERSION_OR_CIPHER_MISMATCH) This problem is showing from maybe 3or more months........ I NEED HELP!!!!!!!! Im UNABLE TO OPEN THE SITES I WANT My system is Windows XP ANYONE SOMEONE HELPPPPPPPPPPPPPPPPPPPPPPPPPPP If I'm right this isn't YOUR problem, it's the website's problem for having an invalid certificate. If I'm right, you would see this error in every browser you try. Confirm this by trying with another browser or two. If confirmed, only the website can fix the error by getting and installing a valid certificate. I am surprised that they haven't gotten more complaints and fixed the problem. 3 months is a long time to tolerate this. <<SL>> Tip Give Link to comment Share on other sites More sharing options...
BugSir007 Posted January 4, 2016 Report Share Posted January 4, 2016 Hi, May we know the website you are visiting? And which version of Maxthon are you using please? You may consider to try the portable version of Maxthon. Tip Give Link to comment Share on other sites More sharing options...
Jessica Lily Posted January 5, 2016 Author Report Share Posted January 5, 2016 Hello and Thank you..... You see that the same site which is unable to open up in mine is able to open in another computer in MAXTHON.... And @BugSir007 this is one of the site im unable to open up... https://www.template.net/ And to mention that few months back the websites used to open up in computer....... So Please help me out on this Regards Tip Give Link to comment Share on other sites More sharing options...
magg Posted January 5, 2016 Report Share Posted January 5, 2016 9 minutes ago, Jessica Lily said: Hello and Thank you..... You see that the same site which is unable to open up in mine is able to open in another computer in MAXTHON.... And @BugSir007 this is one of the site im unable to open up... https://www.template.net/ And to mention that few months back the websites used to open up in computer....... So Please help me out on this Regards No problem here with page you mentioned. You still didn't answer the questions - which version of Maxthon are you using? First of all try to clear your cache and cookies in Maxthon - and then check this problematic site once again. You could also perform clean Maxthon installation - here you'll find last stable version http://forum.maxthon.com/index.php?/topic/17794-maxthon-cloud-browser-for-windows-v4481000-officially-released/ or newest beta http://forum.maxthon.com/index.php?/topic/18303-maxthon-browser-for-windows-v4902400-beta-released/. Here you'll find more infos about similar to your issue https://forums.techguy.org/threads/solved-error-113-net-err_ssl_version_or_cipher_mismatch-unknown-error.1035904/ . Try to follow steps from this thread. Tip Give Link to comment Share on other sites More sharing options...
BugSir007 Posted January 5, 2016 Report Share Posted January 5, 2016 16 minutes ago, Jessica Lily said: Hello and Thank you..... You see that the same site which is unable to open up in mine is able to open in another computer in MAXTHON.... And @BugSir007 this is one of the site im unable to open up... https://www.template.net/ And to mention that few months back the websites used to open up in computer....... So Please help me out on this Regards Hi, Thanks for more details. Here on my side the page opens without any problem. I don't seem to see any certificate related issue at all. If the same page is working fine on other computer in Maxthon, then it could be a particular issue with your current version. As Magg mentioned above, please try to run a clean install of the last stable or beta version of Maxthon. Tip Give Link to comment Share on other sites More sharing options...
Jessica Lily Posted January 5, 2016 Author Report Share Posted January 5, 2016 Well.. Thanks a lot quys.... 1 question is where can i find my version of Maxthon?? and i have a lot of favourites if i uninstall then my FAVS r gone! ANy help? Tip Give Link to comment Share on other sites More sharing options...
magg Posted January 5, 2016 Report Share Posted January 5, 2016 20 minutes ago, Jessica Lily said: Well.. Thanks a lot quys.... 1 question is where can i find my version of Maxthon?? and i have a lot of favourites if i uninstall then my FAVS r gone! ANy help? Click Maxthon Menu then navigate to About... (check my screenshot) You can easily backup your favorites and other settings - just use Maxthon Passport for sync. Then all your important things like favorites, saved passwords and so one will be saved to Cloud. Thanks Cloud sync you don't need to worry about losing your settings. Take a look also at this useful troubleshooting thread http://forum.maxthon.com/index.php?/topic/13264-maxthon-troubleshooting-tips-and-tricks/ Tip Give Link to comment Share on other sites More sharing options...
Jessica Lily Posted January 5, 2016 Author Report Share Posted January 5, 2016 Thanks a lot @Magg for your Kindest response.... Im using MX v4.4.6.2000 and im updating it right now.... If this issue persists i will create a Passport do as you say.. Will keep you updated... Thanks a Lot!!! I Owe You.. Tip Give Link to comment Share on other sites More sharing options...
Jessica Lily Posted January 5, 2016 Author Report Share Posted January 5, 2016 Hello guys.... I updates maxthon and i felt no changes.... same errors.... if this condition persists then i will have to leave maxthon forever which i don't want to... Do you think the problem might be my computer..? Its super old and used Windows XP but the sites used to open up months back Cant find out whats wrong... @magg @BugSir007 @SnowLeopard CAN SOMEBODY GIVE ME A SOLUTION???? Tip Give Link to comment Share on other sites More sharing options...
SnowLeopard Posted January 5, 2016 Report Share Posted January 5, 2016 58 minutes ago, Jessica Lily said: Hello guys.... I updates maxthon and i felt no changes.... same errors.... if this condition persists then i will have to leave maxthon forever which i don't want to... Do you think the problem might be my computer..? Its super old and used Windows XP but the sites used to open up months back Cant find out whats wrong... @magg @BugSir007 @SnowLeopard CAN SOMEBODY GIVE ME A SOLUTION???? One thing to test that I do not recall you doing in this thread is trying to log in with another browser. Try that. It will help to determine if the error is a real invalid certificate or something else. <<SL>> Tip Give Link to comment Share on other sites More sharing options...
BugSir007 Posted January 6, 2016 Report Share Posted January 6, 2016 10 hours ago, Jessica Lily said: Hello guys.... I updates maxthon and i felt no changes.... same errors.... if this condition persists then i will have to leave maxthon forever which i don't want to... Do you think the problem might be my computer..? Its super old and used Windows XP but the sites used to open up months back Cant find out whats wrong... @magg @BugSir007 @SnowLeopard CAN SOMEBODY GIVE ME A SOLUTION???? Hi again, Does the same website work fine in other browsers? Please make sure your computer system date and time is correct. If the time is wrong then Right-click on date and time shown in Taskbar notification area and select "Adjust date/time" option. Tip Give Link to comment Share on other sites More sharing options...
qiuzhihuxian Posted January 6, 2016 Report Share Posted January 6, 2016 what's the situation now? How can you solve it? Tip Give Link to comment Share on other sites More sharing options...
Jessica Lily Posted January 9, 2016 Author Report Share Posted January 9, 2016 Hello Everyone! Thanks a Lot for your Patience, Love and Support! Ive read @BugSir007 and @SnowLeopard answers and well actually they don't The Time and Date is Correct in my computer @BugSir007 I only use Chrome and Maxthon so i tried to open the same in Chrome and and yes it opened but only selective websites which din't open in Maxthon ( There are still few websites that dont open up!! ) Has somebody else have the Same issue?? Due to this problem i'm unable to open up some of my major important sites... PLEASE HELP ME OUT OF THIS! And too remind that every website was working well and good in my computer maybe 2 months ago.. Till I remember this problem came up all of a sudden and I thought it will get ok by itself but the problem is Worsening day by day PLEASE HELP ME FIND A SOLUTION FOR THIS! @BugSir007 @magg @SnowLeopard Tip Give Link to comment Share on other sites More sharing options...
7twenty Posted January 9, 2016 Report Share Posted January 9, 2016 7 hours ago, Jessica Lily said: ( There are still few websites that dont open up!! ) If other sites aren't working in Chrome as well, then there is something going on with the site or your PC. Try running the portable version of Maxthon and see what happens. Tip Give Link to comment Share on other sites More sharing options...
AkisS Posted January 11, 2016 Report Share Posted January 11, 2016 Hello, i also have the same problem with a particular site. It started a few days ago saying that the site has an invalid certificate. It happens only to Maxthon, not to other browsers. (I tried it to Chrome and Firefox, all latest versions) From what i saw, MX see the ssl377474.cloudflaressl.com, the other browsers see the ssl377476.cloudflaressl.com Common Name. and i don't know how to set MX to see the new certificate. I cleared all my cookies, history and cache, i updated the UA to latest version, i also exported the new certificate from Firefox and imported it into Maxthon, but the problem still exists. I use MX 4.4.8.1000 Portable Win7 64bit, the date time are correct and the site is: https://tainies.online/ Thanks in advance for any help Tip Give Link to comment Share on other sites More sharing options...
-ody- Posted January 11, 2016 Report Share Posted January 11, 2016 46 minutes ago, AkisS said: the site is: https://tainies.online/ no issue here with this site you may try this : http://answers.microsoft.com/en-us/windows/forum/windows_xp-performance/error-invalid-certificate-when-trying-to-access/3f3e1d40-9ce3-40b4-9dc4-a1dcfb18bf85?db=5&auth=1 Tip Give Link to comment Share on other sites More sharing options...
AkisS Posted January 11, 2016 Report Share Posted January 11, 2016 2 hours ago, -ody- said: no issue here with this site you may try this : http://answers.microsoft.com/en-us/windows/forum/windows_xp-performance/error-invalid-certificate-when-trying-to-access/3f3e1d40-9ce3-40b4-9dc4-a1dcfb18bf85?db=5&auth=1 Thanks -ody- for your answer and the site you suggested but my knowledge is low for starting modifications with root certificates or registry values. In addition i don't understand why this issue is being only to Maxthon. I hope in next update that little problem will be fix. Tip Give Link to comment Share on other sites More sharing options...
7twenty Posted January 11, 2016 Report Share Posted January 11, 2016 4 hours ago, AkisS said: I use MX 4.4.8.1000 Portable Win7 64bit, Are you using a passport account? If yes, what happens when you don't login and navigate to the site? 4 hours ago, AkisS said: From what i saw, MX see the ssl377474.cloudflaressl.com, the other browsers see the ssl377476.cloudflaressl.com Maxthon is seeing ssl377476 for me. Seems that it's not updating the certificate properly. Are the issued/valid to dates correct? Also, do you have any security software (Kaspersky) running? If so, try disabling that temporarily and see if that helps. Tip Give Link to comment Share on other sites More sharing options...
AkisS Posted January 11, 2016 Report Share Posted January 11, 2016 3 hours ago, 7twenty said: Are you using a passport account? If yes, what happens when you don't login and navigate to the site? Yes 7twenty, i'm always connected to my passport. I just logged out to test it, but nothing happened. The notification about the expired certificate is still here. I have Eset Smart Security running and Mx ABP. Disable them both, nothing changed. P.S. I forgot to mention that i can access the site. Sometimes Mx don't let me to refresh some pages and suggest me to Don't visit it or visit with my own risk. The same happens in my wife's laptop with Win7 32 bit. Because i updated Maxthon through portableapps.com i thought that there was some problem with the update. I just downloaded and run the same version from here, without logging to passport but it's the same again. OK, isn't that a big issue, it's just annoying. I love Maxthon, i use it from the MyIE2 time and it will be always my default browser with it's goods and bads. Like all i wait for Mx5 and i hope that it will be soon and everything will be fine. Thank you all guys for all your work and help! Tip Give Link to comment Share on other sites More sharing options...
AkisS Posted January 12, 2016 Report Share Posted January 12, 2016 Just an update: Using Win 8.1 same pc same Maxthon (portable), everything looks ok. No notification about expired certificate. So the problem is in my Windows7, not in my lovely Maxthon. Tip Give Link to comment Share on other sites More sharing options...
Jessica Lily Posted February 17, 2016 Author Report Share Posted February 17, 2016 On Sun Jan 10 2016 03:38:57 GMT+0530 (India Standard, 7twenty said: If other sites aren't working in Chrome as well, then there is something going on with the site or your PC. Try running the portable version of Maxthon and see what happens. I did try but in Vain... How does one fix the prob with my lap.. anyone any answer? Tip Give Link to comment Share on other sites More sharing options...
Jessica Lily Posted February 17, 2016 Author Report Share Posted February 17, 2016 Hello Everyone... Im sorry but i guess ive been Mean really mean.. Ive been not coming here due to my Neck Deep work.. I just wanted to Know... Is there NO solution for this? @SnowLeopard, @BugSir007, @m▲gg, @qiuzhihuxian, @7twenty, @-ody-, @AkisS BTW im using a Compact Laptop, Windows XP Tip Give Link to comment Share on other sites More sharing options...
