LlexX Posted December 20, 2015 Report Share Posted December 20, 2015 Im using dual screen setup, playing a game on the left one, and keeping maxthon open on the right one. When im playing the game and want to make a screenshot i hit the Print Screen hotkey and the SnapShot Region selection turns on, and my game freezes, the Prt Scr hotkey is not set for SnapShot, it's on the default CTRL+1 and CTRL+2 hotkeys, and the Maxthon window isn't even active, but the SnapShot still gets activated. Haven't experienced this annoying problem with the older version. Ofc i could change the ScreenShot hotkey for the game to another key, but when you used that key for 20+ years... you kinda don't wanna do that... Is there any other way to disable the Prt Scr hotkey to work for Maxthon? Or to completely disable SnapShot? Tip Give Link to comment Share on other sites More sharing options...
BugSir007 Posted December 21, 2015 Report Share Posted December 21, 2015 Confirmed! The problem will be looked into ASAP. Tip Give Link to comment Share on other sites More sharing options...
