Kepler Labs NoRender Posted December 7, 2015 Report Share Posted December 7, 2015 Hello, a long time ago a new update introduced the new speed dial, i seen on a picture some had smaller tiles but more than i have (3x4), how to create more tiles ? How to make them smaller ? Tip Give Link to comment Share on other sites More sharing options...
magg Posted December 7, 2015 Report Share Posted December 7, 2015 1 hour ago, Kepler Labs NoRender said: Hello, a long time ago a new update introduced the new speed dial, i seen on a picture some had smaller tiles but more than i have (3x4), how to create more tiles ? How to make them smaller ? You can add Mosaic to Quick Access. Alternative is this extension http://forum.maxthon.com/index.php?/topic/17578-symbaloo-alternative-new-tab-maxthonnitro/ Tip Give Link to comment Share on other sites More sharing options...
SnowLeopard Posted December 7, 2015 Report Share Posted December 7, 2015 2 hours ago, magg said: You can add Mosaic to Quick Access. Alternative is this extension http://forum.maxthon.com/index.php?/topic/17578-symbaloo-alternative-new-tab-maxthonnitro/ There's no need for an extension to get the smaller tiles. One restriction is you can't do what Magg shows on the first tab is you have the Google search bar there. Just left-click on an empty tile in a 2x2 empty block; click on Apps at the top; and add a group then you can drag 4,5,6,7,8, or 9 tiles into the group. It will adjust its configuration as you add tiles. I have on tab with tiles in the same configuration Magg's screen shot shows. <<SL>> PS: The extension may offer additional features that I'm not addressing. Tip Give Link to comment Share on other sites More sharing options...
