AndroidDeveloperLB Posted November 12, 2015 Report Share Posted November 12, 2015 On some websites, such as Google Drive (when I open it from Gmail website), Maxthon insist on switching to IE engine, even though I've never toggled to it.How could it be?I keep toggling it back to the normal engine, and the next time it still goes to IE engine. Link to comment Share on other sites More sharing options...
PHYR Posted November 12, 2015 Report Share Posted November 12, 2015 Be sure the last tab you close on google drive is in ultra mode. It always opens in ultra for me... Link to comment Share on other sites More sharing options...
BugSir007 Posted November 13, 2015 Report Share Posted November 13, 2015 Google drive always opens in Ultra mode for me.My UA is the default one.You may check your browsing settings in advanced settings. For me only "Enable smooth scrolling' is ticked.Maybe you can tick "Always useUltra mode" option in advanced settings to see what happens. Link to comment Share on other sites More sharing options...
AndroidDeveloperLB Posted November 13, 2015 Author Report Share Posted November 13, 2015 Be sure the last tab you close on google drive is in ultra mode. It always opens in ultra for me...Gmail is in ultra mode, and I open Google drive from there, and still it opens in IE mode. Link to comment Share on other sites More sharing options...
AndroidDeveloperLB Posted November 13, 2015 Author Report Share Posted November 13, 2015 Google drive always opens in Ultra mode for me.My UA is the default one.You may check your browsing settings in advanced settings. For me only "Enable smooth scrolling' is ticked.Maybe you can tick "Always useUltra mode" option in advanced settings to see what happens. I don't use customized UA.Ticking "Always useUltra mode" doesn't help.Maxthon version: 4.4.8.1000 Link to comment Share on other sites More sharing options...
Emreskopi Posted December 30, 2015 Report Share Posted December 30, 2015 I have the same here. For a few weeks or a month. This disgusts me much. Google Services are important for us. Can't use Drive anymore. Disabled UA customization or tried all available choices. Also checked and unchecked always use Ultra. Both didn't help. Needs and urgent solution. Link to comment Share on other sites More sharing options...
Emreskopi Posted January 13, 2016 Report Share Posted January 13, 2016 I've just found out the related option preventing Google Drive. I unchecked "tell websites not to follow me" (or whatever, I use Maxthon in Turkish) I also unchecked "prevent webpages to open a window" (or whatever, I use Maxthon in Turkish) It worked. Then one by one I checked them again. It didn't effect the result first. After a while Google Drive become prevented again. So these are the obstacles. Link to comment Share on other sites More sharing options...
