Give a tip
Problem with MXPlay
RLB
For the last two days whenever I try to go to MXGames it takes forever to load then I get a page with just the following
没该数据库:mxgame
Which if Google translate can be trusted is some kind of database error.  The page this comes from is http://www.mxplay.net/mx_switch.php?big=hwayjr&middle=shoucang
If I got to mxplay.net/index.html I can get the page but when I try to log in I get either a "failed to load" or a "maxthon api error" message.
BTW I am using Maxthon 4.4.8.1000
Tip   Give
Is this actually Maxthon support??
This is where the support link takes me but there doesn't seem to be any support going on.  If this isn't support can some one provide the link to support?
If you are going to tell me to go to support in MXGames then you need them to fix the error listed above so I can log in to MXGames to file a support request.
Tip   Give
Apparently it is based on the site linked from...
But to be honest i'm not sure how much Maxthon actually has to do with it. Maybe an Admin might be able to have a look?
I'd recommend sending notification via the http://www.mxplay.net/support.php page. Use the "Report a Bug" link, or the "directly contact the MXPlay customer service team" option.
Also the support link on http://www.mxplay.net/Wartune/ leads to http://support.r2games.com which may be the provider for their services. I'd shoot them a ticket as well.
Sorry I can't be of anymore help, but hope that leads you in the right direction.
Tip   Give
Thanks for the response.  Unfortunately the support page isn't working either when you try to continue on, it wants me to log in and that part isn't working.  But you did help me find an email address I can use.
Tip   Give
