ckd1945 Posted October 7, 2015 Report Share Posted October 7, 2015 If someone outther has had the same problem I would appreciate some help with getting it to work again. Tip Give Link to comment Share on other sites More sharing options...
No.1MaxthonFan Posted October 8, 2015 Report Share Posted October 8, 2015 If someone outther has had the same problem I would appreciate some help with getting it to work again.Have not had any problem here. Are you getting ads on sites and is it on all sites? Which version of Maxthon are you using please? Windows 10 64-bit build 10525/Windows 10 Mobile build 10512 Tip Give Link to comment Share on other sites More sharing options...
14615246 Posted October 8, 2015 Report Share Posted October 8, 2015 If someone outther has had the same problem I would appreciate some help with getting it to work again.Hmm...try disabling it and re enabling it again....I don't have that problem...or is it the fact that you have a virus...try scanning it.That'll fix your problem. Tip Give Link to comment Share on other sites More sharing options...
-ody- Posted October 8, 2015 Report Share Posted October 8, 2015 If someone outther has had the same problem I would appreciate some help with getting it to work again.you may want to read this : http://forum.maxthon.com/index.php?/topic/17615-dns-unlocker-still-needs-to-be-removed-right-now/ Tip Give Link to comment Share on other sites More sharing options...
A.S. Posted October 8, 2015 Report Share Posted October 8, 2015 If someone out ther has had the same problem I would appreciate some help with getting it to work again.Many users from Russia have the same problems. ABP just turned off everytime. And Russian moderator ask me to write the guide who to fix this issue. When I did it, he block me and now I cannot see my topic in VK. I'll try to find someone who can copy my text there and translate it in English. But I need time.*Prt Sc* Tip Give Link to comment Share on other sites More sharing options...
