Excel online - problem inserting data in a cell
Hi,
on Excel online (https://onedrive.live.com/) it is impossible to insert data in cell at the first attempt.
When you move in a cell for the first time and start to write the cursor move to the left immediately after the first char you insert, resulting in something wrong.
For example if you write "Apple" you'll have "ppleA" (with the cursor: "pple|A").
You instinctively press right or left key resulting in get out of editing this cell.
Then you have to double click on the previous cell, move the cursor and correct the error.
This happen with cell that have any kind of format: amount, currency, text, date... so sometime you don't recognize the error!
This happens for more than two months so it is not a temporary problem.
This made using Excel online IMPOSSIBLE.
Maxthon 4.4.7.1000 on Windows 64bit.
Thanks,
Alessandro
