Huma22 Posted September 21, 2015 Report Posted September 21, 2015 HiWithin the last days using latest Maxthon release (4.4.7.3000) I noticed few problems I'd like to raport.1. Problem with video playback on http://tvgry.pl. When video is switched to full screen mode, normally navigation buttons and mouse pointer disapear after 2 seconds of playback and show back if I move my mouse. With latest Maxthon navigation buttons hides just to show up the second later. Basicly it looks like mouse pointer and navigation buttons blinking. There was nothing wrong with this site in 4.4.7.1000.2. When saving site to Pocket using bookmarklet (created as described here https://getpocket.com/add I need to be logged in to Pocket to do it. With new Maxthon iven when I'm logged in bookmarklet popup says I need to log in. And I can't as I'm logged in already. Needed to switch to Pocket addon which doesn't work as I would like it to. Checked for both problems on 4.4.7.1000 and found nothing.
magg Posted September 21, 2015 Report Posted September 21, 2015 HiWithin the last days using latest Maxthon release (4.4.7.3000) I noticed few problems I'd like to raport.1. Problem with video playback on http://tvgry.pl. When video is switched to full screen mode, normally navigation buttons and mouse pointer disapear after 2 seconds of playback and show back if I move my mouse. With latest Maxthon navigation buttons hides just to show up the second later. Basicly it looks like mouse pointer and navigation buttons blinking. There was nothing wrong with this site in 4.4.7.1000.2. When saving site to Pocket using bookmarklet (created as described here https://getpocket.com/add) I need to be logged in to Pocket to do it. With new Maxthon iven when I'm logged in bookmarklet popup says I need to log in. And I can't as I'm logged in already. Needed to switch to Pocket addon which doesn't work as I would like it to. Checked for both problems on 4.4.7.1000 and found nothing.About issue no.1- also confirm this problem.
No.1MaxthonFan Posted September 21, 2015 Report Posted September 21, 2015 HiWithin the last days using latest Maxthon release (4.4.7.3000) I noticed few problems I'd like to raport.1. Problem with video playback on http://tvgry.pl. When video is switched to full screen mode, normally navigation buttons and mouse pointer disapear after 2 seconds of playback and show back if I move my mouse. With latest Maxthon navigation buttons hides just to show up the second later. Basicly it looks like mouse pointer and navigation buttons blinking. There was nothing wrong with this site in 4.4.7.1000.2. When saving site to Pocket using bookmarklet (created as described here https://getpocket.com/add) I need to be logged in to Pocket to do it. With new Maxthon iven when I'm logged in bookmarklet popup says I need to log in. And I can't as I'm logged in already. Needed to switch to Pocket addon which doesn't work as I would like it to. Checked for both problems on 4.4.7.1000 and found nothing.I also confirm issue #1. Windows 10 64-bit build 10525/Windows 10 Mobile build 10512
BugSir007 Posted September 22, 2015 Report Posted September 22, 2015 Hi Humaa22 , Thanks for reaching out.1.The problem with navigation buttons and mouse pointer disappearing can be reproduced. We have reported it for the fix.2.https://getpocket.com/add) the link is no longer working....Did you try Maxthon retro mode ?
Huma22 Posted September 22, 2015 Author Report Posted September 22, 2015 Hi Humaa22 , Thanks for reaching out.1.The problem with navigation buttons and mouse pointer disappearing can be reproduced. We have reported it for the fix.2.https://getpocket.com/add) the link is no longer working....Did you try Maxthon retro mode ?1. Thank You for that. Patiently waiting for the fix. 2. There is something wrong with Pocket Help ATM, I also can't get into it. Basicly there was described how to create a bookmarklet to save sites to Pocket. You create a Favorites bar button with string like this javascript:(function(){var e=function(t,n,r,i,s){var o=[2173840,3093560,4509333,2094451,9143325,3143431,3940945,4131752,5820470,1884262];var i=i||0,u=0,n=n||[],r=r||0,s=s||0;var a={'a':97,'b':98,'c':99,'d':100,'e':101,'f':102,'g':103,'h':104,'i':105,'j':106,'k':107,'l':108,'m':109,'n':110,'o':111,'p':112,'q':113,'r':114,'s':115,'t':116,'u':117,'v':118,'w':119,'x':120,'y':121,'z':122,'A':65,'B':66,'C':67,'D':68,'E':69,'F':70,'G':71,'H':72,'I':73,'J':74,'K':75,'L':76,'M':77,'N':78,'O':79,'P':80,'Q':81,'R':82,'S':83,'T':84,'U':85,'V':86,'W':87,'X':88,'Y':89,'Z':90,'0':48,'1':49,'2':50,'3':51,'4':52,'5':53,'6':54,'7':55,'8':56,'9':57,'\/':47,':':58,'?':63,'=':61,'-':45,'_':95,'&':38,'$':36,'!':33,'.':46};if(!s||s==0){t=o[0]+t}for(var f=0;f<t.length;f++){var l=function(e,t){return a[e[t]]?a[e[t]]:e.charCodeAt(t)}(t,f);if(!l*1)l=3;var c=l*(o[i]+l*o[u%o.length]);n[r]=(n[r]?n[r]+c:c)+s+u;var p=c%(50*1);if(n[p]){var d=n[r];n[r]=n[p];n[p]=d}u+=c;r=r==50?0:r+1;i=i==o.length-1?0:i+1}if(s==273){var v='';for(var f=0;f<n.length;f++){v+=String.fromCharCode(n[f]%(25*1)+97)}o=function(){};return v+'93f37eddea'}else{return e(u+'',n,r,i,s+1)}};var t=document,n=t.location.href,r=t.title;var i=e(n);var s=t.createElement('script');s.type='text/javascript';s.src='https://getpocket.com/b/r4.js?h='+i+'&u='+encodeURIComponent(n)+'&t='+encodeURIComponent(r);e=i=function(){};var o=t.getElementsByTagName('head')[0]||t.documentElement;o.appendChild(s)})()and clickig it saves site to Pocket. It doesn't work wtth latest Maxthon release saying I need to login to Pocket. But I already am logged in. Checked the retro mode - bokkmarklet doesn't work at all.
Simbiat Posted September 25, 2015 Report Posted September 25, 2015 Can I just add, that for me Drag-And-Drop to site likes Facebook, VK.com, Mediafire and alike does not work in neither mode?
BugSir007 Posted September 25, 2015 Report Posted September 25, 2015 Can I just add, that for me Drag-And-Drop to site likes Facebook, VK.com, Mediafire and alike does not work in neither mod Sorry? You meant drag and drop content to Facebook or opening a link in Facebook by drag and drop? Drag and drop a link from Facebook to open in a new tab works fine for mew here...
7twenty Posted September 25, 2015 Report Posted September 25, 2015 2.https://getpocket.com/add) the link is no longer working....Did you try Maxthon retro mode ?) at the end. Have fixed the link in the first post. Still won't help you as you can't download the bookmarklet without logging in to getpocket. Thankfully Huma22 did paste it here for testing, but again without signing up for an account it's hard to test.2. When saving site to Pocket using bookmarklet (created as described here https://getpocket.com/add I need to be logged in to Pocket to do it. With new Maxthon iven when I'm logged in bookmarklet popup says I need to log in. And I can't as I'm logged in already. Needed to switch to Pocket addon which doesn't work as I would like it to. Checked for both problems on 4.4.7.1000 and found nothing.Check your cookie settings in case it's checking for something weird with that. And if you can compare any other settings between your 447.1000 install to .3000Anything in particular that the addon isn't doing that it should? Maybe let the creator know so they might be able to fix or implement something to make it better.
Huma22 Posted September 26, 2015 Author Report Posted September 26, 2015 Check your cookie settings in case it's checking for something weird with that. And if you can compare any other settings between your 447.1000 install to .3000Anything in particular that the addon isn't doing that it should? Maybe let the creator know so they might be able to fix or implement something to make it better.Checked the cookies. All enabled and well. Also cleared the browser cache. No result. And there was no change in setting while changing Mx version.And as to the addon, my only problem with it is that while saving a site to Pocket, it opens a new page to inform my the site was saved and where I can add tags to it. Bookmarklet does the same but with a popup layer I could ignore if not adding a tag and just close the site. With addon I have to aditionally close the new page. So basicly to get the same with addon I need more clicking. And I like to keep my clicking as limited as possible. I have made a chat with addon creator that can be read here. He says he can't do it like the bookmarklet does beause of Maxthon developers restrictions.
Simbiat Posted September 27, 2015 Report Posted September 27, 2015 Sorry? You meant drag and drop content to Facebook or opening a link in Facebook by drag and drop? Drag and drop a link from Facebook to open in a new tab works fine for mew here...drag content
