MaxIP Posted September 5, 2015 Report Share Posted September 5, 2015 I use Maxthon for browser based gaming because it usually faster and more stable than other browser. I am now not able to fully load Wartune. It almost loads into the starting place then hangs. I have tried the following: Cleared everything; cache, cookies, history, etc. Reinstalled Maxthon Updated Adobe Flash per the instructions in the pinned post. Any suggestions you can give would be appreciated. Tip Give Link to comment Share on other sites More sharing options...
BugMiss006 Posted September 6, 2015 Report Share Posted September 6, 2015 Hi, Can you give us a specifc address? then we can test it directly, besides, will you encounter the same problem when you are usring other browsers ?? thanks for your feedback . Tip Give Link to comment Share on other sites More sharing options...
MaxIP Posted September 6, 2015 Author Report Share Posted September 6, 2015 Yes, it still works fine on other browsers; IE, Chrome, Firefox The address I go to is https://www.kabam.com/games/wartune/play I doubt that it matters but I'm on server 88 Thank you. Tip Give Link to comment Share on other sites More sharing options...
7twenty Posted September 7, 2015 Report Share Posted September 7, 2015 Test in Retro mode. Test with changing the UserAgent to Firefox or Chrome, Main Menu > Settings > Advanced > Others > Customise User agent. Tip Give Link to comment Share on other sites More sharing options...
MaxIP Posted September 8, 2015 Author Report Share Posted September 8, 2015 Hello. I did this changing it to Firefox that I know works. It did not help. Game still freezes on loading. Thank you. Tip Give Link to comment Share on other sites More sharing options...
7twenty Posted September 8, 2015 Report Share Posted September 8, 2015 Did you test in Retro Mode? Main Menu > Switch Browser Core. Or press the lightning button on the address bar so it changes to a blue broken page. Tip Give Link to comment Share on other sites More sharing options...
MaxIP Posted September 10, 2015 Author Report Share Posted September 10, 2015 Tried it in Retro Mode. Still not loading fully. Tip Give Link to comment Share on other sites More sharing options...
MaxIP Posted September 17, 2015 Author Report Share Posted September 17, 2015 any more suggestions? Tip Give Link to comment Share on other sites More sharing options...
7twenty Posted September 17, 2015 Report Share Posted September 17, 2015 Try #9 & #10 in troubleshooting. If the game was working fine but now it doesn't, either something has changed on their end causing a conflict with maxthon, or something changed on your side. Testing with a clean version with no extensions/userdata takes that out of the equation. Tip Give Link to comment Share on other sites More sharing options...
chits Posted October 13, 2015 Report Share Posted October 13, 2015 I ran into the same problem after Flash updated to Version 19 (I was on version 16). I tried everything posted in troubleshooting and found that I could replicate the issue on my other PC's. Even PC's that had never had Maxthon installed would not play the Flash game if version 19 is installed.I removed Flash from my system and installed Version 18 but the problem persisted, Dropped to 16 and problem went away. Now I do have some other issue with this version of flash but Every time I try the newer version Wartunes and now I'm noticing other Flash Based Games that do not work. All the time they will work in other Browsers (FireFox, IceDragon, Chrome, Edge, WaterFox, and Pale Moon) with no issue on the new Flash. The best assumption on my part is that Maxthon is handling something differently in the new version of Flash or Flash is sending a command that only the Maxthon browser is seeing and halting on in these games.It would be nice to get them to work together as the Flash performance is slowly getting worse on the older version. "You have version 16,0,0,305 installed" Tip Give Link to comment Share on other sites More sharing options...
slank Posted October 13, 2015 Report Share Posted October 13, 2015 It has nothing to do with the flash version apparently, I had no problem loading or playing Wartune with FP19.0.0.185. I'm using version Mx4.4.7.3000 on win10b10565 with gpu acceleration enabled and no user agent selected in advanced settings. Tip Give Link to comment Share on other sites More sharing options...
chits Posted October 13, 2015 Report Share Posted October 13, 2015 Where did you get x 4.4.7.3000? 4.4.7.1000 is all I'm able to install. Is that a browser or the client that R2games uses? I have no user agent and GPU is on. Also I can load Wartunes into a new game as well but that dose not fix the problem. The issue comes into play once you have made past the staging areas of the game. Also they do not seems to be affecting all providers of the game. Update, I went and downloaded version 4.4.7.3000 and installed (it replaced the internal with version 18 so I updated to 19). Now I'm back to Maxthon just locking up on the main page as it logs in. If I revert my Flash to 16 it works again. I know it makes no sense and it must be something the game is pushing up to the browser but the fact is that it only happens in Maxthon. Tip Give Link to comment Share on other sites More sharing options...
chits Posted October 16, 2015 Report Share Posted October 16, 2015 I had a new Laptop come in today. Windows 7 Pro 64Bit.I Installed Maxthon from the web site. Flash was Updated to the newest version from Adobe.I opened Maxthon, went to Kabam.com, Logged in and as soon as the game loaded so that I could see the Top Icons it locks up.Installed FireFox..Works just fine, same with Chrome, and IE. There has to be something in that game that Maxthon dose not like but I never see an error. Tip Give Link to comment Share on other sites More sharing options...
slank Posted October 16, 2015 Report Share Posted October 16, 2015 There has to be something in that game that Maxthon dose not like but I never see an error. Or something you are doing in Maxthon that is affecting your game play. Please check that you are using IE proxie settings Tip Give Link to comment Share on other sites More sharing options...
