محمد جہانزیب عادل Posted August 19, 2015 Report Share Posted August 19, 2015 The Linkedin-Pulse section script is not running properly on maxthon. I am unable to edit, compose or publish a post on it. Pl. check and fix in the next release. Thanks Link to comment Share on other sites More sharing options...
BugSir006 Posted September 7, 2015 Report Share Posted September 7, 2015 Hi, Could you please give us the webpage link that your Maxthon had problem with so we could have a check? And which version of Maxthon & operating system are you using? Thanks. Link to comment Share on other sites More sharing options...
محمد جہانزیب عادل Posted September 14, 2015 Author Report Share Posted September 14, 2015 Hi BugSir06 I ever use the latest version of maxthon. The problem is persisting. The link for new long post(article) writing at LinkedIn is as under: https://www.linkedin.com/pulse/article/new?trk=hp-share-poncho-pencil Pl. check n fix in latest version. Link to comment Share on other sites More sharing options...
محمد جہانزیب عادل Posted October 2, 2015 Author Report Share Posted October 2, 2015 The messaging control doesn't work while the following option is checked..."Press Enter to Send Message" in reply box.https://www.linkedin.com/messaging/Pl. check and fix in next version.Thanks.Adil. Link to comment Share on other sites More sharing options...
BugSir006 Posted October 12, 2015 Report Share Posted October 12, 2015 Hi,Sorry for the late reply. I checked the two linkedin functions and they both work perfectly fine here. Maybe try disable Ad Block Plus, make sure you have a clean installation of the newest version of Maxthon.Best. Link to comment Share on other sites More sharing options...
محمد جہانزیب عادل Posted November 10, 2015 Author Report Share Posted November 10, 2015 https://www.linkedin.com/pulse/article/new?trk=hp-share-poncho-pencil Pl. check the link given above and get back with the latest position and maxthon screen shot. thanks. I am using portable edition of maxthon from protableapps.com However, I tried it on all editions. Link to comment Share on other sites More sharing options...
