Ravi Kd Posted June 2, 2015 Report Share Posted June 2, 2015 hey i m from india and i cant get search suggestions in the search box but when i connect to uk vpn i get them help me plzz Link to comment Share on other sites More sharing options...
joemax Posted June 2, 2015 Report Share Posted June 2, 2015 Where did you get your Maxthon installation from? Link to comment Share on other sites More sharing options...
7twenty Posted June 3, 2015 Report Share Posted June 3, 2015 That looks like quite an old version of Maxthon. I'd recommend downloading the most recent release and installing that. Hopefully it will also solve the issue you are having. Latest version here Link to comment Share on other sites More sharing options...
BugMiss006 Posted June 3, 2015 Report Share Posted June 3, 2015 Hi, Thanks for your question. You can upgrade to out latest version of browser which you can find by clicking here.http://forum.maxthon.com/index.php/topic/15204-maxthon-cloud-browser-for-windows-v4452000-official-released/?p=82993In this version, you can change the searching engine in settings. Link to comment Share on other sites More sharing options...
Ravi Kd Posted July 27, 2015 Author Report Share Posted July 27, 2015 no i have the latest version however when i connect to uk server thru vpn then is starts showing suggestions plzzz help me Link to comment Share on other sites More sharing options...
Ravi Kd Posted August 9, 2015 Author Report Share Posted August 9, 2015 anyone help me please Link to comment Share on other sites More sharing options...
7twenty Posted August 9, 2015 Report Share Posted August 9, 2015 Have you tried going through this: Maxthon Troubleshooting & Tips and Tricks and have you made any changes to your hosts file? Link to comment Share on other sites More sharing options...
Ravi Kd Posted August 12, 2015 Author Report Share Posted August 12, 2015 can you tell me what is host file Link to comment Share on other sites More sharing options...
7twenty Posted August 13, 2015 Report Share Posted August 13, 2015 can you tell me what is host file If you don't know what it is, then you probably didn't change it. That wouldn't be the problem. Go through the link provided. Link to comment Share on other sites More sharing options...
Ravi Kd Posted September 13, 2015 Author Report Share Posted September 13, 2015 i have gone through the link provided but the same thing occurs again and again SOMEONE PLEASE HELP ME OUT OF THIS BROWSER ITS THE ONLY DEFECT I HAVE FOUND IN MAXTHON, REST IT IS ALL GOOD Link to comment Share on other sites More sharing options...
7twenty Posted September 14, 2015 Report Share Posted September 14, 2015 Seeing as it doesn't happen when using a VPN i'm thinking it's possible the URL required for search suggestions is being blocked by your ISP for some reason. When you type into the address bar do you get search suggestions there as well with and without VPN? Link to comment Share on other sites More sharing options...
Ravi Kd Posted September 30, 2015 Author Report Share Posted September 30, 2015 i get suggestions only when i connect to vpn Link to comment Share on other sites More sharing options...
7twenty Posted October 1, 2015 Report Share Posted October 1, 2015 Didn't answer the last question, but anyway... When not using the VPN, can you do the following:Open a cmd window (Start > Run > cmd.exe)Enter the command, ping api.bing.com, press Enter and post the information that shows. It should look similar to the following:Pinging api.bing.com [191.234.5.80] with 32 bytes of data: Reply from 191.234.5.80: bytes=32 time<1ms TTL=128 Reply from 191.234.5.80: bytes=32 time<1ms TTL=128 Reply from 191.234.5.80: bytes=32 time<1ms TTL=128 Reply from 191.234.5.80: bytes=32 time<1ms TTL=128If it doesn't and you get any sort of error then it's probably being blocked by a firewall rule, which should be fixable. Or your ISP, which if this is the case then there is nothing that can be done. Link to comment Share on other sites More sharing options...
