EddyFicio Posted May 31, 2015 Report Share Posted May 31, 2015 When I try to search in maxthon multisearch, it automatically search in baidu (chinese version of google) is pretty annoying, I don't speak chinese and I DOESN´T LET ME MULTISEARCH!! where´s the bar of the maxthon multisearch pages? I prove that is not an external software, only happends when I change to maxthon multi search engine Tip Give Link to comment Share on other sites More sharing options...
-ody- Posted May 31, 2015 Report Share Posted May 31, 2015 When I try to search in maxthon multisearch, it automatically search in baidu (chinese version of google) is pretty annoying, I don't speak chinese and I DOESN´T LET ME MULTISEARCH!! where´s the bar of the maxthon multisearch pages? I prove that is not an external software, only happends when I change to maxthon multi search engine try to disable "preload" in address bar settings probably same issue as http://forum.maxthon.com/index.php/topic/15174-search-alias-issue-with-4451800-and-2000/ Tip Give Link to comment Share on other sites More sharing options...
EddyFicio Posted May 31, 2015 Author Report Share Posted May 31, 2015 try to disable "preload" in address bar settings probably same issue as http://forum.maxthon.com/index.php/topic/15174-search-alias-issue-with-4451800-and-2000/ It works thanks XDD Tip Give Link to comment Share on other sites More sharing options...
BugMiss006 Posted June 1, 2015 Report Share Posted June 1, 2015 Hi, Thanks for your question. You can upgrade to our latest version http://forum.maxthon.com/index.php/topic/15204-maxthon-cloud-browser-for-windows-v4452000-official-released/?p=82993 andswitch the search engine in settings. Tip Give Link to comment Share on other sites More sharing options...
