DevicesFix Posted May 27, 2015 Report Share Posted May 27, 2015 Hello, I want to reset my account NOT browser just ACCOUNT, because something was synchronized with wrong settings when I log off my account the browser work like I want, but when log again then its suck,,,, i did default restore but its wont help so my question HOW i can reset account to be like "new" or how i can delete account and create it again for lost this settings ? Tip Give Link to comment Share on other sites More sharing options...
DevicesFix Posted May 27, 2015 Author Report Share Posted May 27, 2015 Thank You, I did like you say, deleted folder with my user name then open browser and I have to log but when i login again all settings come back, that why before I asked how to reser ACCOUNT on your site not settings of browser.... Tip Give Link to comment Share on other sites More sharing options...
DevicesFix Posted May 27, 2015 Author Report Share Posted May 27, 2015 No, I mean maxthon passport or can u delete my database with it ? because when you login all settings are downloaded from passport to my pc I wanna make new synchronization Tip Give Link to comment Share on other sites More sharing options...
DevicesFix Posted May 27, 2015 Author Report Share Posted May 27, 2015 ]Yes I have it disable all of them, I have no idea what more its synchronized if the browser is on guess account work fine when, I login work wrong even if synchronize is DISABLE so I cannot delete my ACCOUNT ?! its sound like a joke ...... OK then we maybe can sort out it by different way First of all what is annoying its even if I open new tap in "box search" I have the same words what before for explain: You can see 3 Tabs no matter if I open 10 or 100 the word still in box thats happend only with my account Tip Give Link to comment Share on other sites More sharing options...
DevicesFix Posted May 27, 2015 Author Report Share Posted May 27, 2015 well everything is fine if im not login ,,,, if I login then I had this issue OK then we maybe can sort out it by different way First of all what is annoying its even if I open new tap in "box search" I have the same words what before for explain: You can see 3 Tabs no matter if I open 10 or 100 the word still in box thats happend only with my account Notatka20150527171058.pngNotatka20150527171132.pngNotatka20150527171155.png Tip Give Link to comment Share on other sites More sharing options...
DevicesFix Posted May 27, 2015 Author Report Share Posted May 27, 2015 Well I tested many time and its happend only when Im logged but anyway Thanks for your time! Tip Give Link to comment Share on other sites More sharing options...
DevicesFix Posted May 27, 2015 Author Report Share Posted May 27, 2015 Yes I have the same like you on picture Tip Give Link to comment Share on other sites More sharing options...
BugMiss006 Posted May 28, 2015 Report Share Posted May 28, 2015 Hi, Thanks for your question. Maybe you can uncheck all the option here and try again. Tip Give Link to comment Share on other sites More sharing options...
7twenty Posted May 28, 2015 Report Share Posted May 28, 2015 Go to Settings > Search engine and check your search engine URL for google. Make sure the URL doesn't have "test" at the end. It should end with q=%us If it does, delete it and everything should work as normal. If for some strange reason it's on one of the default installed search URLs then you'll have to delete it and add it again as they can't be modified. Tip Give Link to comment Share on other sites More sharing options...
7twenty Posted May 28, 2015 Report Share Posted May 28, 2015 Hmmm, still doesn't hurt to check. There's no reason why it should be there unless there is a save option from a previous search, or the dev's forgot to remove it before compiling for the final release. Doesn't happen here, so i'm confused. Tip Give Link to comment Share on other sites More sharing options...
DevicesFix Posted May 28, 2015 Author Report Share Posted May 28, 2015 Hello thanks for to everyone. Hi, Thanks for your question. Maybe you can uncheck all the option here and try again. I did it and still the same Go to Settings > Search engine and check your search engine URL for google. Make sure the URL doesn't have "test" at the end. It should end with q=%us If it does, delete it and everything should work as normal. If for some strange reason it's on one of the default installed search URLs then you'll have to delete it and add it again as they can't be modified. its looks right I think we should rename the tittle of topic, finally it's not a settings reset problem? I think so its more like or the dev's forgot to remove it before compiling for the final release. Tip Give Link to comment Share on other sites More sharing options...
