Svilen Posted January 18, 2015 Report Share Posted January 18, 2015 Hello. I'm still getting problems on some sites: There is one of the problem sites: https://kibana.bedegaming.net Unfortunately this is a company limited site so you won't have access to it. However there is the problem: When i get in Ultra mode i can browse the site and the site is fully functional however the icons used with in the html are not rendered in Maxthon Here is how the those icons looks like in Maxthon: http://gyazo.com/708634d2340804c65e8cb52326810e29 This is how they look in Chrome for instance: http://gyazo.com/8d643a790b7c35ed24939842909df090 When i switch to Retro mode i am able to see those icons http://gyazo.com/f98e0589150d64fb235a69262f5cfd9a However I'm getting the error message (as shown on the last screenshot) and the site is not working anymore. Please advice is it possible to somehow workaround this. PS: It might be worth to say that the site is on https:// protocol and i have to press "Run unsafe scripts" on Chrome in order to display the site correctly. Regards. Link to comment Share on other sites More sharing options...
7twenty Posted January 19, 2015 Report Share Posted January 19, 2015 Any chance of posting the HTML here, or at least the section with the offending code? (assuming it doesn't breach any privacy issues with the company). However I'm getting the error message (as shown on the last screenshot) and the site is not working anymore. Please advice is it possible to somehow workaround this.When running in Retro, ensure that the "Enable standard rendering in Retro Mode" option is checked in advanced settings to allow it to run with the current version Trident renderer. The page probably doesn't like running in IE compatibility mode which is what happens when that option is unchecked. Link to comment Share on other sites More sharing options...
Svilen Posted January 19, 2015 Author Report Share Posted January 19, 2015 There is the HTML in RetroMode http://pastebin.com/TfAYeFca and this is the code in UltraMode: http://pastebin.com/Xr1p7tY2 The "Enable standard rendering in Retro Mode" option is checked. Link to comment Share on other sites More sharing options...
Svilen Posted February 3, 2015 Author Report Share Posted February 3, 2015 Hi guys, I was just wondering is there any additional info on that annoying problem. There is one more site to add although there is plenty of sites that use tag which is not rendered in Ultra mode. The site is: https://github.com/explore the good thing is that most of the sites are working (with some compromise) in retro mode as well (except for kibana) so i can switch cause it is really annoying to browse without be able to see some images. I was just wondering why is that not considered as a bug i can imagine the tag is pretty popular. Link to comment Share on other sites More sharing options...
BugSir007 Posted February 4, 2015 Report Share Posted February 4, 2015 Hi Svilen, Sorry for the late reply and sorry for the inconvenience. I have reported your problem to our engineering team and right now we are investigating on it. I'll be back to you soon, when we are done. Stay tuned. Thanks. Link to comment Share on other sites More sharing options...
BugSir007 Posted February 4, 2015 Report Share Posted February 4, 2015 Hi again , After some investigation, we found out that the problem could be due to many factors including webpage display settings. I would suggest that you try to reset "Web page font" ( in Wed page display options under advanced settings) to Default to see if it is effective or everything works properly. Thanks for your support! 11675 Link to comment Share on other sites More sharing options...
Dinataspace Posted February 4, 2015 Report Share Posted February 4, 2015 It looks like a web font icons rendering is not working properly on your Mx version. Based on your pastebin, Kibana used bootstrap framework which use a web font icons like on Twitter and I think it's so popular on web tech today. So, If the icon on Twitter can render properly, it should be displayed well on Kibana too. And you rite. Nowaday, html tag is commonly used to display a web font icons like font awesome and so on. But I can confirm that it also working properly on ultra mode too (trial error with recent Mx version/v4.4.3.x and v4.4.4.x). Here's the ultra mode web font icons rendering on github and font awesome site. 11677 Last, what Mx version are you using? else, make sure all web content (especially css/web font is css part) has been loaded and not blocked by adhunter/adblock rules or blocked by extension (violent monkey script, stylish rules etc). Link to comment Share on other sites More sharing options...
Svilen Posted February 6, 2015 Author Report Share Posted February 6, 2015 BugSir007 replied at 2015-2-3 22:09 Hi again , After some investigation, we found out that the problem could be due to many factors incl ... Thanks Guys, setting the web font the default seems to fix my problem. Thank you very much it bothers me for more than an year I'll keep you posted if i notice any further issues regarding that but so far everything looks good. Thank you once again guys. Link to comment Share on other sites More sharing options...
BugSir007 Posted February 6, 2015 Report Share Posted February 6, 2015 Ofocurse Svilen, It's our pleasure to help you.:handshake Thanks for your support! Link to comment Share on other sites More sharing options...
