Give a tip
Search-Engine IXQUICK
MartinB
 Share
  • 3 weeks later...
furkanavshar replied at 2014-12-28 02:25 back.gif
Hi MartinB (:
You can add this URL to Search Engine list: https://ixquick.com/do/search?q=
Hi,
Ixquick is my preferred search engine and it works fine in other browsers. However, in Maxthon I always get this message: 'Navigation to the webpage was cancelled' every time I search for something in the search bar or the address bar. The only way I can search using Ixquick/Startpage is by going through their sites, which adds another step. Any thoughts?
Tip   Give
MaxVas replied at 2015-1-14 20:23 back.gif
Hi,
Ixquick is my preferred search engine and it works fine in other browsers. However, in Maxtho ...
it works fine here. I created an entry using this url https://ixquick.com/do/search?q=and an alias "i"
I just type the "i" key into address bar then "space" and then the word I search...
11389
Tip   Give
odyssee replied at 2015-1-14 10:41 back.gif
it works fine here. I created an entry using this urland an alias "i"
I just type the "i" key int ...
Ixquick worked, but not Startpage (even though they're basically the same thing). Thanks all the same, and I will have to stick with Ixquick.
Tip   Give
 Share
