Give a tip
How to delete topright search engine
BugSir007 replied at 2014-10-23 18:59 back.gif
Hi,
Glad to talk to you.
I'm not sure why it's not being deleted on your end.
it doesn't work
http://i.imgur.com/QBdzPFp.gif
see in this gif, when i delete baidu, it automatically transfer to maxthon multisearch
then when i try to delete maxthon multisearch it wouldn't allow me
Tip   Give
and having that extra is hindering the browser.I doubt it's doing much at all.
I think you have to have at least one that will be set to default. So if you're going to add one of your own, add that first and then delete whatever is left.
Tip   Give
7twenty replied at 2014-10-23 19:26 back.gif
I think you have to have at least one that will be set to default. ...
To me, there is no need for an additional search engine on the topright if the main bar does the same thing. Most browser have changed to having the main bar doing one thing instead of another clogging the screen
http://upload.wikimedia.org/wikipedia/en/b/bc/IE_11_Wikipedia.png
http://www.thechromesource.com/wp-content/uploads/2011/08/mock3.png
http://www.zdnet.com/i/story/62/58/002391/chrome19.jpg
Tip   Give
Chain Reactan replied at 2014-10-24 13:37 back.gif
To me, there is no need for an additional search engine on the topright if the main bar does the s ...
OK, that's what I thought you meant, but your reply to BugSir007 made me think otherwise.
Menu > View > Uncheck Search Box. It will disappear!
I agree with you as well, it has become somewhat redundant since you can easily search using the address bar. And with aliases setup, it's just as easy to search a different search engine to your default one.
Tip   Give
 Share
