martinstz Posted September 29, 2014 Report Share Posted September 29, 2014 Hi! In my site i have a drop down menu and flash. When i click the drop down menu, it's stay under flash only in Maxthon: In other browsers i haven't this problem: I added code but it did not work in Maxthon. My site is www.petrovy.com Can someone help me? Thank you in advance! Link to comment Share on other sites More sharing options...
-ody- Posted September 29, 2014 Report Share Posted September 29, 2014 I don't get such an issue here 10061 Link to comment Share on other sites More sharing options...
martinstz Posted September 29, 2014 Author Report Share Posted September 29, 2014 I tried on 3 different PC's with Maxthon latest version and on everyone i have that problem. Link to comment Share on other sites More sharing options...
-ody- Posted September 29, 2014 Report Share Posted September 29, 2014 martinstz replied at 2014-9-29 09:41 I tried on 3 different PC's with Maxthon latest version and on everyone i have that problem. I tried again : I get the issue using retro mode. you may check that you're in ultra ? Link to comment Share on other sites More sharing options...
BugSir007 Posted September 29, 2014 Report Share Posted September 29, 2014 Hi martinstz Thank you for reproting this issue. Here, on my end i can confirm the same problem. The dropdown context menu displays under Flash content. Recorded for the fix! Thanks again for your support! Link to comment Share on other sites More sharing options...
Guest Posted September 29, 2014 Report Share Posted September 29, 2014 Here I have the issue with both mode! Link to comment Share on other sites More sharing options...
Guest Posted September 29, 2014 Report Share Posted September 29, 2014 And Firefox have the same problem! (Opera, IE and Chrome are OK) Link to comment Share on other sites More sharing options...
7twenty Posted September 29, 2014 Report Share Posted September 29, 2014 Same issue here, Ultra and Retro - also with FF. OK in Chrome. So not directly related to Maxthon? Link to comment Share on other sites More sharing options...
SWFlash0 Posted September 29, 2014 Report Share Posted September 29, 2014 Change wmode="transparent" to wmode="opaque" and it should fix your problem Link to comment Share on other sites More sharing options...
martinstz Posted October 2, 2014 Author Report Share Posted October 2, 2014 SWFlash0 replied at 2014-9-29 06:03 Change wmode="transparent" to wmode="opaque" and it should fix your problem I change the code but dropdown menu continue to stay under flash. Link to comment Share on other sites More sharing options...
martinstz Posted October 3, 2014 Author Report Share Posted October 3, 2014 martinstz replied at 2014-10-2 02:21 I change the code but dropdown menu continue to stay under flash. SWFlash0, i did it and then return back the old code, because nothing happened. Link to comment Share on other sites More sharing options...
