SriRag Posted August 10, 2014 Report Share Posted August 10, 2014 Hi All, When I press a new Tab ("+ Sign") two or more new tabs are loading simultaneously. Also when a website page loads and during that when I click a new Tab ("+ Sign") two or more tabs are loading simultaneously. Please fix this issue ASAP. Regards, SriRag. Tip Give Link to comment Share on other sites More sharing options...
BugSir007 Posted August 11, 2014 Report Share Posted August 11, 2014 Hi SriRag, Welcome to Maxthon forum. We are very sorry for this inconvenience brought to you. When did this problem started happening please? Would you check if there is any crash file generated when tabs refreshes ( %temp%Maxthon crash folder)? If there is one, please zip it and send it to us at help@maxthon.com At the same time, you may clear your browser's cookies and disable GPU acceleration in Maxthon advanced settings to see if there improvements. Thanks. Tip Give Link to comment Share on other sites More sharing options...
7twenty Posted August 11, 2014 Report Share Posted August 11, 2014 What is loading on these new tabs? blank pages? Homepages? QuickAccess? Duplicate of the current page? Tip Give Link to comment Share on other sites More sharing options...
SriRag Posted August 11, 2014 Author Report Share Posted August 11, 2014 Hello Moderators.... Thanks for your helpful suggestion. No doubt Maxthon browser is one of the best browser available in the world. 2 Weeks back the issue started. I am not having any browser crash issues with Maxthon. If you delete the browser's cookies (Not recommended by Maxthon itself), I need to enter a new code again and again in gmail mail checkup which is under 2 step verification. Also I disabled GPU acceleration in Maxthon which finds no use for the issue I am facing. The same issue still persists. I hope by one day it will get fixed. Regards, SriRag. Tip Give Link to comment Share on other sites More sharing options...
SriRag Posted August 11, 2014 Author Report Share Posted August 11, 2014 Hello Moderators, When I try to click a link from a web page ... (or) try to open a new blank page (from the tab by pressing "+" sign) ..... a webpage/blank page having two tabs is opening with same URL .... This is my issue. Can u help me please ? Regards, SriRag. Tip Give Link to comment Share on other sites More sharing options...
BugSir007 Posted August 11, 2014 Report Share Posted August 11, 2014 Hi, Thank for your quick reply. Please try the latest beta version http://forum.maxthon.com/thread-12304-1-1.html ,it works fine. Tip Give Link to comment Share on other sites More sharing options...
SriRag Posted August 11, 2014 Author Report Share Posted August 11, 2014 Hi, Thanks. I will follow your instruction and try the latest beta version. Regards, SriRag. Tip Give Link to comment Share on other sites More sharing options...
15r17e80n12e Posted August 11, 2014 Report Share Posted August 11, 2014 7twenty replied at 2014-8-10 18:53 What is loading on these new tabs? blank pages? Homepages? QuickAccess? Duplicate of the current pag ... today this site automaticaly kept loading when i was going through the article and opening other few sites Chinese smartphone maker Xiaomi apologises for unauthorised data access - The Economic Times http://economictimes.indiatimes.com/news/international/business/chinese-smartphone-maker-xiaomi-apologises-for-unauthorised-data-access/articleshow/40061957.cms pls go through the following images. this happened on 3rd Aug 2014 used both versions stable(4.4.1.300) and beta (4.4.2.1400) Private and normal mode Reader mode on/off 9429 9430 9431 9432 9433 9434 Tip Give Link to comment Share on other sites More sharing options...
joemax Posted August 11, 2014 Report Share Posted August 11, 2014 I can't confirm any problems today, the site opened and I read the entire article with no other tabs opening. Edit: I've also tried disabling adhunter and popup blocker, but still no new tabs????? Also tried reader mode with no ill effects. Tip Give Link to comment Share on other sites More sharing options...
BugSir007 Posted August 12, 2014 Report Share Posted August 12, 2014 15r17e80n12e replied at 2014-8-11 07:11 today this site automaticaly kept loading when i was going through the article and opening other ... I just opened the link you provided read through it and browsed other sites but i couldn't reproduce your problem. Maybe you could lear the browser's cookies and cache files and refresh the page . Also you may need to make sure you are not duplicating the tab accidently. Thanks. Tip Give Link to comment Share on other sites More sharing options...
15r17e80n12e Posted August 12, 2014 Report Share Posted August 12, 2014 joemax replied at 2014-8-11 10:03 I can't confirm any problems today, the site opened and I read the entire article with no other tabs ... thank you for checking the link it doesn't happen regularly, once in a blue moon it happens and performing additional tasks Tip Give Link to comment Share on other sites More sharing options...
15r17e80n12e Posted August 12, 2014 Report Share Posted August 12, 2014 BugSir007 replied at 2014-8-11 18:21 I just opened the link you provided read through it and browsed other sites but i couldn't reprod ... thank you for checking the link it doesn't happen regularly, once in a blue moon it happens The questions you have put forward to me are relevant and valid. what an irony even i couldn't reproduce the problem with the same link today. Clearing browser's cookies, cache files and refresh the page don't help. its solution is i need to close the whole browser then reopen the browser.(Guessing ) not full proof soln. i have ticked the auto clear on exit, clear browser data. which helped. i'm facing this issue from July but not an every day issue as stated earlier few times in Jully, August till date twice. to be honest i was juggling between the normal and private mode but the modes had different link. how can duplicating tab accidently happen (even i had this same question back of my mind, keyboard shortcuts for duplicating, when you right click on the tab there is no shortcut mentioned on duplicate tab, unknowingly pressing some key combinations which may lead to duplicating of tab not sure might have happened) when i am on normal mode going through the site or article and the different site getting duplicated on the private mode same vice-versa On 3rd August i just opened 1 site in normal mode & another site in private mode they were repliating after a gap of almost 10 mins even i checked with betaas well as the lattest stable release. thank you. Tip Give Link to comment Share on other sites More sharing options...
