battRado Posted July 17, 2014 Report Share Posted July 17, 2014 Hi, recently I found that the sound which Maxthon produces while playing song from Youtube isn't good (the same song played by Chrome, for example, sounds better). Why is that? (Chrome and Maxthon both use Webkit, right?) I have YouTube Center DB 330 extension installed and Maxthon 4.4.1.2000. Tip Give Link to comment Share on other sites More sharing options...
BugSir007 Posted July 17, 2014 Report Share Posted July 17, 2014 Hi battRado, Glad to talk to you. Really sorry for the inconvenience. It's my first time to hear a problem like this. Would you please provide us with the specific link to test? What happens if you disabled the Youtube center extension? Looking forward to hearing from you. Thanks for your support of Maxthon Tip Give Link to comment Share on other sites More sharing options...
battRado Posted July 17, 2014 Author Report Share Posted July 17, 2014 If I delete the extension, the problem seems to disappear (I'm not completely sure, though). If you want to test, try with this for example: Tip Give Link to comment Share on other sites More sharing options...
QIK5L Posted July 18, 2014 Report Share Posted July 18, 2014 Sounds ok to me, using youtube center extension 352 and playing the 360p version, 720p version sounds even better tho. Tip Give Link to comment Share on other sites More sharing options...
battRado Posted July 18, 2014 Author Report Share Posted July 18, 2014 There are so many settings in youtube center. Is there a difference in sound quality between HTML5 , flash , agressive flash players? Thanks Tip Give Link to comment Share on other sites More sharing options...
QIK5L Posted July 19, 2014 Report Share Posted July 19, 2014 And my setting for player type is "Flash" Tip Give Link to comment Share on other sites More sharing options...
battRado Posted July 19, 2014 Author Report Share Posted July 19, 2014 When I set HTML5 player type, I get slightly better sound than Flash player type. Maxthon had some problems with HTML5 and youtube, but they seem to be fixed now. Tip Give Link to comment Share on other sites More sharing options...
