puf_the_majic_dragon Posted July 8, 2014 Report Share Posted July 8, 2014 The application Dual Monitor Taskbar adds a taskbar to a second monitor in Windows 7. The taskbar icons for most running apps will move to the second taskbar when I move the app to my second monitor. Maxthon does not do this, so if I use Maxthon on my second monitor, the taskbar icon stays on the taskbar on my first monitor. Since many other applications do switch taskbars correctly, I assume this is something in Maxthon's code. I haven't tested it with Windows 8, which has a built-in second taskbar. Can anyone confirm this behavior and tell me if it's something that Maxthon can correct? Thanks! Link to comment Share on other sites More sharing options...
BugSir007 Posted July 9, 2014 Report Share Posted July 9, 2014 Hi, Tried here but it couldn't move. Possibly Dual Monitor Taskbar does not detect Maxthon. Would you report this issue to Dual Monitor Taskbar to see what they say? I can see some other applications having the same problem also. Link to comment Share on other sites More sharing options...
puf_the_majic_dragon Posted July 9, 2014 Author Report Share Posted July 9, 2014 It looks like someone already reported this issue to them, but the Dual Monitor Taskbar does not seem to have had any support for over a year and I think it's an abandoned project. Link to Maxthon bug report on SF page It does look like whoever reported the bug knows more about the issue than I do. To quote from the bug report "The reason is Maxthon window has no WS_SYSMENU style." Is this something Maxthon can add to fix this issue? Link to comment Share on other sites More sharing options...
Fray Posted July 23, 2014 Report Share Posted July 23, 2014 As I know Dual Monitor Taskbar has many bugs. Try to download Actual Multiple Monitors. This is a MM manager, commercial, but has 30-days trial. http://actualtools.com/multiplemonitors/ Link to comment Share on other sites More sharing options...
